4 Replies Latest reply on Dec 22, 2010 7:02 PM by Shiva.Kosaraju
    Error while invoking a process
    Shiva.Kosaraju
      Hi Team,
      I get the following error while invoking a process.
      ALC-DSC-125-000: com.adobe.idp.dsc.registry.EndpointNotEnabledException: SOAP endpoint is not enabled for: ExtractingXML/ReadResource
      at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.validateEndpoint(AbstractMes sageReceiver.java:258)
      at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeCall(SoapSdkEndpoint. java:136)
      at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke(SoapSdkEndpoint.java :81)
      at sun.reflect.GeneratedMethodAccessor755.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
      at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
      at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
      at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
      at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
      at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
      at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
      at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
      at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
      at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
      at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper. java:227)
      at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
      at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:292)
      at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:26)
      at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:42)
      at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java :43)
      at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:41)
      at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletC ontext.java:3496)
      at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
      at weblogic.security.service.SecurityManager.runAs(Unknown Source)
      at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2 180)
      at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2086)
      at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1406)
      at weblogic.work.ExecuteThread.execute(ExecuteThread.java:201)
      at weblogic.work.ExecuteThread.run(ExecuteThread.java:173)
      Can anyone please help me with this error.
        • 1. Re: Error while invoking a process
          Hodmi Level 4
          It looks like the service you are calling has had its SOAP endpoint disabled.  Login to the adminui and go to: Home > Services > Applications and Services > Endpoint Management
          Filter on the SOAP endpoint and check to see if it is disabled.  You can enable it on that screen as well.
          • 2. Re: Error while invoking a process
            Shiva.Kosaraju Level 1
            hi,
            I searched for Read Resource as well as ReadResource.
            But there were no results displayed in the SOAP endpoint list displayed at the path you mentioned below. Could you kindly say what shall i do next?
            • 3. Re: Error while invoking a process
              Hodmi Level 4
              I checked my server (which has all the default Adobe services) and the only service I have that comes close is:
              • the Repository service's "Read Resource Content" operation.  In the list that comes up as RepositoryService.
              • The Barcode's Extract to XML service.  In the list that comes up as                BarcodedFormsService
              Neither of these is an exact match to the error. Is your process calling a sub process you built?  Does that service actually exist on the server?  If you do a record/playback (in workbench) on which step does the process fail?
              If you look through the entire list of SOAP services (in Adminui) are any of them disabled?
              • 4. Re: Error while invoking a process
                When i check the SOAP services i see all of them are enabled. Attaching the screenshot for the repository services you suggested.
