6 Replies Latest reply on Dec 22, 2010 5:56 PM by dupred
    How to convert DataServices.Result into an Arraylist or ArrayCollection?
    dupred
      I want to use an ArrayCollection or an ArrayList as a data provider
      for a dataGrid, and then later in a Graph.
      The problem is that the starting point is the FLEX Builder 4 created "datasource.lastResult" value Objects.
      I don't know how to access anything but the Column names.
      The fields returned are:
           gmtdate,hostname,CPUBusy
      I want to show CPU busy for "N" number of hosts.
      So I need to change my result from the SQL query in Action Script into:
          gmtdate, hostname1_CPUbusy, hostname2_CPUbusy, hostnameN_CPUbusy
      Are there any samples of how to convert the .lastResult into an ArrayList?
      The result set is Object based and I can't figure out how to read it.
      David
