2 Replies Latest reply on Dec 22, 2010 2:00 PM by nordinkhm
    Drag an Drop and Cursors
    nordinkhm
      I have three lists, each one filled with xml data through an arraycollection.
      Below those lists i have a datagrid. People can drag items from those lists to the datagrid.
      The datagrid consists of three columns: Product, Price and Pieces.
      When people drag the same item from those lists i want to count them and show the result in the third column
      of the datagrid.
      I tried to use a cursor to count the same items and show the result in the third column of the datagrid, but i don't know
      behind which event i have to put this function:
      private
      function aantalpizza():void{
      cursor = acaantal.createCursor();
      var pizzaobject:Object = {item:mypizzas.selectedItem.item};
      if(cursor.findAny(pizzaobject))
      cursor.current.aantal ++
      else
      mypizzas.selectedItem.aantal = 1;
      Does anyone have an idea?
        • 1. Re: Drag an Drop and Cursors
          rtalton Level 4
          You can use the DragEvent of type "dragComplete".
          • 2. Re: Drag an Drop and Cursors
            nordinkhm Level 1
            i tried the following code:
            private
            function aantalpizza(ev:DragEvent):void{
            cursor =
            else
            <mx:DataGrid
            dragComplete="aantalpizza(event)" dataProvider="{acaantal}" id="dgbestelling" dropEnabled="true">
            <mx:columns>
            <mx:DataGridColumn dataField="item" headerText="Artikel" resizable="false" width="150"/>
            <mx:DataGridColumn dataField="prijs" headerText="Prijs"/>
            <mx:DataGridColumn dataField="aantal" headerText="Aantal"/>
            </mx:columns>
            </mx:DataGrid>
            it didn't work, i need the datafield "aantal" to update if the same item is being dragged to the datagrid
            ==> "aantal" means quantity, so if the same item is being dragged , it needs to count the quantity.
