4 Replies Latest reply on Dec 22, 2010 9:44 PM by saisri2k2
    How can I make dynamic menu from a xml?
    Koyel_flex Level 1
      My xml is:
      <?xml version="1.0" encoding="UTF-8" ?>
      <nodes>
      <node>
      <category_id>3</category_id>
      <parent_id>2</parent_id>
      <name>Mobile</name>
      <is_active>1</is_active>
      <position>1</position>
      <level>2</level>
      <children>
      <node>
      <category_id>6</category_id>
      <parent_id>3</parent_id>
      <name>Nokia</name>
      <level>3</level>
      <children></children>
      </node>
      <node>
      <category_id>7</category_id>
      <name>Samsung</name>
      <position>2</position>
      <level>3</level>
      </node>
      </children>
      </node>
      </nodes>
      How can I make dynamic menu from this xml?
        • 1. Re: How can I make dynamic menu from a xml?
          saisri2k2 Level 4
          Your xml is wrong.. please post the correct xml
          • 2. Re: How can I make dynamic menu from a xml?
            saisri2k2 Level 4
            Even then, I'm thinking you hve to create a xml out of this and then create a dynamic menu out of it. If you are tring with a full xml like this, you will end up with so many other sub menus under the main menu.
            • 3. Re: How can I make dynamic menu from a xml?
              Koyel_flex Level 1
              <nodes>
              <node>
              <name>Mobile</name>
              <level>2</level>
              <children>
              <node name="Nokia" category_id="6" parent_id="3" is_active="1" position="1" level="3">
              <node name="Nokia N79" category_id="7" parent_id="3" is_active="1" position="2" level="3" />
              <node name="Nokia N95" category_id="7" parent_id="3" is_active="1" position="2" level="3" />
              <node name="Nokia N97" category_id="7" parent_id="3" is_active="1" position="2" level="3" />
              </node>
              <node name="Samsung" category_id="7" parent_id="3" is_active="1" position="2" level="3">
              </node>
              </children>
              </node>
              <node>
              <category_id>4</category_id>
              <name>Laptop</name>
              <level>2</level>
              </node>
              <node>
              <category_id>5</category_id>
              <name>Monitor</name>
              <position>3</position>
              <level>2</level>
              </node>
              <node>
              <category_id>8</category_id>
              <name>Camera</name>
              <position>4</position>
              <level>2</level>
              </node>
              </nodes>
              Is this correct format to create dynamic menu?
              • 4. Re: How can I make dynamic menu from a xml?
                Koyel_flex Level 1
                How can I convert this xml what I have post in forum 1st  into that xml what I have sent 2nd tym?
