0 Replies Latest reply on Dec 23, 2010 1:19 AM by Sen Imagines
    Line Chart with DataTips if the XML has one point
    Sen Imagines
      I am using Flex 3 Line chart.
      The data for the chart is provided thru a HTTP service from a back end function (XML format)
      I use 2 Line series.
      The chart displays the DataTips properly if there are more than one number of nodes (data points for Flex to plot).
      But, if the XML contains a single node, no line is displayed.
      It is required to show atleast a point to be plotted corresponding to that XML node.
      To achieve this, I used a CrossItem Renderer for the chart series so that a cross indication appears corresponding to that data point.
      <mx:itemRenderer>
           <mx:Component>
                <mx:CrossItemRenderer/>
           </mx:Component>
      </mx:itemRenderer>
      But the DataTip does not appear when I mouse over that cross in the chart.
      Can i know how to achieve showing the DataTips if the XML has one point.
      - Sen
