6 Replies Latest reply on Dec 25, 2010 9:49 PM by jpdobrin
    new comp arrived, few headaches in setup of drives
    jpdobrin Level 1
      First off, just wanted to say thank you to everyone (and Mr. Harm Millard) who advised me on putting together a new system. I just wanted to verify a few things before moving forward installing programs and such.
      Booting Win7 64bit pro with a corsair 80gb SSD (will install programs on here as well). The BIOS is set to IDE boot for my chipset. I tried AHCI initially because corsair recommended it, but ran into many problems after that. The main one being that when I added any other drives the BIOS would give me disk errors and wouldn't boot the OS.
      Currently have 2 samsung f4 2tb drives for data. I want to use this as my RAID 0 setup for video and photo editing. I do not have a raid controller card. I ran into many many headaches using the MOBO's raid controller card with the BIOS and just gave up. I got my system to boot normally after resetting the BIOS and just created a Striped Volume / dynamic disk in Win7 disk management using the two drives. I never realized you could do this just in windows without using a raid controller card in the BIOS. Is this problematic?
      Also, any advice on booting a SSD os drive in IDE mode vs AHCI? I'm afraid to change my bios settings again back to ahci, because it caused my system to not POST and required a wipe of the cmos/bios headache (because for some reason my legacy usb drivers stop working making my keyboard/mouse stop working.. fun!)
      My BIOS has 3 options for drives, IDE, AHCI and X.H.D. which is Gigabyte's "extreme hard drive" for raid systems. I couldn't get this to work and am scared to try it.
      I should mention that the 3 drives are connected to my MOBO's Intel ICH10R sata controller. The optical drive and external case esata port is connected to the gigabyte sata controller port.
      1 corsair 80gb force SSD and two samsung f4's 2tb
      Gigabye GA-X58A-UD3R motherboard
      bfg 1000w PSU
      NVIDIA gtx 580
      12gb adata memory
      dvd optical drive
      (using external Drobo S for data storage)
      happy holidays and thank you everyone in advance for your input
        • 1. Re: new comp arrived, few headaches in setup of drives
          Colin Brougham Level 6
          Since you installed Windows with the BIOS set to IDE mode for your boot drive, the AHCI drivers are disabled; they're installed on the system, but made inactive to shorten boot times. Typically, you'd install Windows after enabling AHCI mode, so the proper drivers are enabled.
          This can be repaired after the fact, and I'd recommend using AHCI mode. Read the following link for more information, background, and the fix (from Microsoft): Error message when you start a Windows 7 or Windows Vista-based computer after you change the SATA mode of the boot drive: "STOP 0x0000007B INACCESSABLE_BOOT_DEVICE". After you enable the drivers, you can enable AHCI mode in the BIOS and you'll be in good shape.
          There really is no reason to use software RAID when you have hardware RAID available. The problem with using software RAID in Windows is that it incurs some processing overhead--the OS already has enough to do, and you'll unnecessarily slow down the entire system, especially when you have a capable built-in RAID controller. I'm curious what problems you ran into with the built-in controller that caused you to give up on it?
          Further to that point, with the shortage of hard drives you have in this system, putting everything on a large software RAID 0 is a recipe for disaster and heartbreak. Should one of the drives go down in a RAID 0, you lose EVERYTHING--not just the data of one drive. It took one time for me to lose everything on a RAID 0 (didn't know much then) before I decided to go another route. With only two drives, you're probably much better off not putting then into an array at all, and instead just use them as two individual drives.
          • 2. Re: new comp arrived, few headaches in setup of drives
            jpdobrin Level 1
            Thank you very much for your quick reply Colin and thank you for the link to the microsoft website.
            I actually installed the OS with AHCI enabled, but I think the drivers were still not working/installed correctly/who knows. In your link, the directions mention altering two lines in regedit.exe and to set both "start" figures to 0
            HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci (this is already set to 0 in my registry)
            HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\IastorV (this is set to 3 in my registry.. I could change it to 0 as well)
            I knew it was too good to be true! Now I realize I had heard of software RAID versus hardware RAID. I guess I won't give up on it yet. The problems I ran into (with my registry settings above) include:
            Even though I installed the OS with AHCI enabled, the OS Corsair SSD drive and bios gives me an error message during POST, if there are other drives connected to the motherboard (this is with the bios set to AHCI and without the windows registry alterations). The error message says something like 'drive read error, press ctrl+alt+delete to restart," and then my usb drivers stop working (no keyboard or mouse), thus I cant enter the bios or even restart... which forces me to reset the CMOS and BIOS settings.
            To answer your other question, I'm not opposed to using a RAID 1 internal setup. But I will also be using an external "Drobo-S" redudant storage system to backup my files. Do you still think a RAID 1 setup is better?
            So here is my proposed plan:
            I have 3 internal drives. The OS corsair SSD 80gb drive. Two separate/identical 2tb samsung drives. They are formatted, healthy, NFTS and windows explorer/dsk management see them and the BIOS sees them in with IDE mode.
            Should I go ahead and modify both registry settings, reboot, go into the BIOS and change the mode back to AHCI?
            If the above is correct, I'm sort of unsure what to do after to utilize my hardware RAID controller. Within windows, I have a Gigabyte RAID configurer (which I think I need to install the drivers during the OS installation). I also have the Intel Matrix Storage Manager/Console, which currently doesn't work because it says "plug-ins failed to load."
            Should I use the Intel Matrix to create my hardware RAID? I think it will work if I change the BIOS (and registry) back to AHCI.
            • 3. Re: new comp arrived, few headaches in setup of drives
              jpdobrin Level 1
              Went ahead and modified the win7 registry to accept AHCI/raid booting and everything went smoothly (so far, whew)
              Currently have my OS on the SSD and I attempted to create a RAID 0 using the two 2tb samsung drives using the bios intel raid controller.
              When I went to setup the drive in windows, the Disk Management utilitiy sees the one raid drive, however there are two partitions created (one around 2 tb and the other around 1.7 tb). Is this normal? Should I create a raid setup using disk management with those two partitions? I'm a little confused.
              • 4. Re: new comp arrived, few headaches in setup of drives
                Bill Gehrke Most Valuable Participant
                Windows requires that the GUID Partition Tables be used in place of the standard Master Boot Record (MBR) partition tables to address more than 2 TB.  You have to select other than the MBR when you format.
                • 5. Re: new comp arrived, few headaches in setup of drives
                  jpdobrin Level 1
                  Well after googling around about 2tb max size for RAID setups in windows 7 and my current MOBO hardware controller, it seems like it's not worth the effort. I should either just use a single 2 TB drive for my working drive, or use a raid 1 2tb setup
                  • 6. Re: new comp arrived, few headaches in setup of drives
                    Harm Millaard Level 7
                    Look here: Adobe Forums: How to access more than 2 TB of disk...
                    When you click on the Overview tab at the top of the Hardware forum, this link is shown in the drop down box, amongst other relevant articles.
