I have just install live cycle Pdf generator. installation log shows installation is successful.I have configure The things which I had to do,like installing
windows office(2007),acrobat reader,change UAC.
now when I want to convert some word document(.doc) to pdf ,It fails to convert,It shows the following messege:
Views
Total Likes
I think you can try to disselect the "" in the
Microsoft Word
Of cause the standard and the defaults in the LC can not be modified directly , you can modify one of them and save it as you need , then disselect the "" , and the same setting for other microsoft office types , then try again .
Good luck with you !
Views
Total Likes
If you still have the problem, please check the path of JAVA environment variable.
KazSakai
Views
Total Likes
right now there is no problem..
.path of java environment variable is ok...
I was using turnkey installation.I dont think in case of turnkey installation we need to set java environment variable ...
If u have 64bit java then u have to install additional 32bit java therefore you have to set environment variable for that 32 bit of java.
I think I had some configuration problem..after reinstallation this problem has been resolved.
Thanking you.
Barun Barik
Views
Total Likes
