9 Replies Latest reply on Dec 26, 2010 11:41 AM by kglad
    How to create a Random Timeline with checks?
    Feed_Me_Info_Plz
      I have a simple multiple question quiz with 100 questions.
      I want the questions to be randomly asked, without repea
      ting a questions as the end works on a scoring system out of the 100 so it needs to ask
      all the questions.
      Question one starts on frame 5 of the timeline and the last question is on frame 105.
      Can someone please assist on how to write this script with the checks?
        • 1. Re: How to create a Random Timeline with checks?
          // begin code
          var frameA:Array = [];
          for(var i:Number=5;i<=105;i++){
          frameA.push(i);
          shuffle(frameA);
          function shuffle(a:Array):Array {
              var len:Number = a.length-1;
              for (var ivar:Number = len; ivar>=0; ivar--) {
                  var p:Number = Math.floor(Math.random()*(ivar+1));
                  var t = a[ivar];
                  a[ivar] = a[p];
                  a[p] = t;
              return a;
          // end code
          // now the first question is on frame frameA[0], the next on frameA[1], etc
          • 2. Re: How to create a Random Timeline with checks?
            Feed_Me_Info_Plz Level 1
            Hi KGLAD,
            Thanks for your speedy response. I have currently a script on the buttons which are the multiple choice answers of on release goto the next frame and the correct answer has a score++. Could you please explain how to incorpirate your script into this and if I could ask if you could explain the workings of your script so I could understand it better for future use.
            • 3. Re: How to create a Random Timeline with checks?
              instead of our nextFrame() or your goto the next frame, use gotoAndStop(frameA[nextframenumber]);
              // begin code
              // the for-loop populates frameA with numbers 5,6,...,105
              frameA.push(i);
              // the shuffle() function randomizes the contents of frameA
              shuffle(frameA);
                      var t = a[ivar];
                      a[ivar] = a[p];
                      a[p] = t;
                  return a;
              // end code
              • 4. Re: How to create a Random Timeline with checks?
                http://rapidshare.com/files/439292244/Learners_Shuffle.fla
                Hi KGLAD,
                Thanks for advice. It seems to work with the random effect however has a few glitches.
                I am attaching a link to a shortened version .fla file of what I am trying to complete. If you could please download then you will see the random works however repeats same frames a few times and does not go to the last frame to give you the final score.
                If you could please assist with this?
                • 5. Re: How to create a Random Timeline with checks?
                  the only free help i offer is via the adobe forums.  in particular, i don't download and correct files unless i'm hired.
                  if you can explain the issue here, i'll continue to help.
                  • 6. Re: How to create a Random Timeline with checks?
                    I do apologise, it was not my intent. I thought that if you s
                    aw the file you would understand the problem. I love trying to sort
                    things out myself and am on the brink of a breakthrough however??
                    The problem is and I will explain with the short version I am trying out first.
                    Frame 1 is the welcome screen and has a start button to start the quiz.
                    Frame 2 the quiz starts and is a multiple answer quiz with 3 answer option only one being correct with the score++ I have on the actions tab the script you sent me of:
                    // begin code
                    frameA.push(i);
                    shuffle(frameA);
                            var t = a[ivar];
                            a[ivar] = a[p];
                            a[p] = t;
                        return a;
                    // end code
                    Each answer is a button and has the gotoAndStop(frameA[0]); script on them:
                    The next frame is the next question and has the 3 buttons as well with the following script: gotoAndStop(frameA[1]);
                    and then so on till frame 6 with the following script on the 3 buttons: gotoAndStop(frameA[5]);
                    It does randomize the questions but seems to repeat questions and does not end up in frame 7 when all questions completed, I assumed with the check it would automatically go to the next frame but am now thinking I need a script to tell it that on completion it needs to go to frame 7.
                    Frame 7 basically does the math of the score++ and gives a total.
                    I do hope you can assit and once again do apologies.
                    Thanks.
                    • 7. Re: How to create a Random Timeline with checks?
                      should be using something  like:
                      // begin code
                      frameA.push(i);
                      shuffle(frameA);
                              var t = a[ivar];
                              a[ivar] = a[p];
                              a[p] = t;
                          return a;
                      var frameIndex:Number=-1;
                      // end code
                      then each button in every frame should use:
                      frameIndex++;
                      if(frameIndex<frameA.length){
                      gotoAndStop(frameA[frameIndex]);
                      } else {
                      //goto the quiz results page.  quiz is complete
                      • 8. Re: How to create a Random Timeline with checks?
                        Thanks for your help KGLAD. I had problems with the
                        quiz still repeating questions however it was because I had the
                        initial script in every frame under my actions layer. That
                        probably reset the the script to start all over again
                        and caused an infinite loop. I have rectified by having the scrip
                        t only in my first frame.
                        It works like a dream.
                        Thank you very much
