7 Replies Latest reply on Dec 23, 2010 11:46 AM by ACS LLC
    Populating cookies from a SQL Query
    ACS LLC Level 1
      I have a SQL query that I know for a fact will produce 4 records without fail
      What I need to do is to store the data on an individual basis so that I can use each record independantly on the following page allowing me to set up hyperlinks based on each one including it's text description (from the query - cat_tiitle , and it's uid from the query, cat_uid)
      I have written some code but it seems a little primative, I am thinking that there might be a better way to do this? I know it's only a small piece of code but it has the potential to be used a LOT so I need to make sure I have this as efficient as possible -->
                <!--- GET THE 4 RECORDS --->
      <CFQUERY NAME="GetCategories" DATASOURCE="#datasource#">
          SELECT cat_uid,cat_title
          FROM categories
          WHERE cat_uid IN (#valuelist(Validateinstall.install_preferences)#)
          ORDER by cat_title
      </CFQUERY>
                <!--- SET UP 4 INDIVIDUAL COOKIES WHICH HAVE THE UID AND THE TITLE --->
      <CFLOOP query="GetCategories">
      <CFCOOKIE NAME="pref_uid_#GetCategories.CurrentRow#" value="#GetCategories.cat_uid#">
      <CFCOOKIE NAME="pref_title_#GetCategories.CurrentRow#" value="#GetCategories.cat_title#">
      </CFLOOP>
                <!--- DISPLAY THE 4 HYPERLINKS --->
      <CFOUTPUT>
      1. <a href="cat.cfm?cat_uid=#cookie.pref_uid_1#,#URLEncodedFormat(cookie.pref_title_1)#"
      class="reg_text">#cookie.pref_title_1#</a>
      2. <a href="cat.cfm?cat_uid=#cookie.pref_uid_2#,#URLEncodedFormat(cookie.pref_title_2)#"
      class="reg_text">#cookie.pref_title_2#</a>
      3. <a href="cat.cfm?cat_uid=#cookie.pref_uid_1#,#URLEncodedFormat(cookie.pref_title_3)#"
      class="reg_text">#cookie.pref_title_3#</a>
      4. <a href="cat.cfm?cat_uid=#cookie.pref_uid_4#,#URLEncodedFormat(cookie.pref_title_4)#"
      class="reg_text">#cookie.pref_title_4#</a>
      </CFOUTPUT>
      Appreciate any thoughts on making this more efficient
      Mark
        • 1. Re: Populating cookies from a SQL Query
          Dan Bracuk Level 5
          It would be more efficient to forgo the cookies and use the query results in your anchor tags.
          • 2. Re: Populating cookies from a SQL Query
            ilssac Level 5
            Is there some reason you don't use SESSION variables.  Which are like COOKIES only better!
            <CFQUERY NAME="Session.GetCategories" DATASOURCE="#datasource#">
                FROM categories
                ORDER by cat_title
            </CFQUERY>
            <cfoutput query="session.GetCategories">
                 <a href="cat.cfm?catuid="#session.GetCategories.cat_uid#",#urlEncodedFormat(session.GetCategories.cat_title)#"
                      class="reg_text">#session.GetCategories.cat_title#</a>
            </cfoutput>
            • 3. Re: Populating cookies from a SQL Query
              ACS LLC Level 1
              that's interesting, I did not know you could read the results of a query directly into a session like that.
              The issue I have is that we are running this on a shared server, and I know that this page could potentially receive a large amount of hits.
              My concern I have is that there could be problems with too many sessions on the server at any time, I have no control over the administrator settings, plus the session could expire.
              I figured that a cookie was a safer way to ensure that I did not have to be too concerned about the server settings.
              • 4. Re: Populating cookies from a SQL Query
                ilssac Level 5
                Sessions do expire.  If you are trying to persist this data for days and days, the first choice would be a database, or other data store, that would store the query recordset tied to a user specific key.  You would then just store the key in a single cookie.
                Working out for there, you can store the recordset itself in a cookie as long as it is not too large.  You just have to incode it, <cfwddx....> would be the old school way to encode it, there are others now adays.
                Or you can continue your current option.  I would probably use a <cfloop from="1" to="4" index="i"> to consolidate that output code some.
                • 5. Re: Populating cookies from a SQL Query
                  ACS LLC Level 1
                  yeah, I did wonder about stuffing that cookie with more data.
                  You think a CFLOOP over the results is quicker than just hard coding it to display each cookie?
                  Output -->
                  class="newhyper_wht_12">#cookie.pref_title_1#</a>
                  class="newhyper_wht_12">#cookie.pref_title_2#</a>
                  <a href="cat.cfm?cat_uid=#cookie.pref_uid_3#,#URLEncodedFormat
                  class="newhyper_wht_12">#cookie.pref_title_3#</a>
                  class="newhyper_wht_12">#cookie.pref_title_4#</a></CFOUTPUT>
                  • 6. Re: Populating cookies from a SQL Query
                    ilssac Level 5
                    I don't know about FASTER?
                    But I would think it would be easier to edit and maintain, which 9 times out of 11 is the more expensive and critical aspect.
                    • 7. Re: Populating cookies from a SQL Query
                      ACS LLC Level 1
                      True, normall I would use a loop but with it being a page that is going to get a lot of traffic I thought for this particular situation I'd avoid the loop, and try to squeeze as much as possible
                      sessions were a no go due to the risk of expiring. It looks like I've actually probably got the best solution in place for my situation.
                      I guess I'll leave it as-is.
                      Thanks for the input guys, I did learn something regarding the sessions into a query, very nice!
                      Mark
