4 Replies Latest reply on Jan 3, 2011 7:37 PM by marieg18350358
    I cannot authorize my Kobo.
    darknight13
      My computer is authorized in my Adobe digital editions, but when I go to open a file on my Kobo, I get a message that the content I am trying to view is locked and than a message to use my adobe id to autorize my ereader with the Adobe Digital Editions. I am totally lost on this
        • 1. Re: I cannot authorize my Kobo.
          marieg18350358
          I have exactly the same problem. Did you figure it out yet? I have tried everything, including calling the help line for my Kobo, and I cannot read files downloaded from the library but, can read free books downloaded from Kobo.
          • 2. Re: I cannot authorize my Kobo.
            marieg18350358 Level 1
            I have now solved my problem. I re-read the manual and there is a trouble shooting section. It suggests that you check your date and time settings as this may cause a problem. Somehow my date and time settings on the Kobo had reverted to an incorrect date even though I had set them and when I changed them to today's date and time I was then able to view new files I downloaded to the Kobo. The files I had tried before did not seem to work ... so, I simply transferred them again and all is now well. Hope this works for others.
            • 3. Re: I cannot authorize my Kobo.
              cathyo14
              I had exactly the same problem - took some advice from another post and this is what I did
              Shut down ADE
              Reset the defaults on my Kobo.(under advanced you can reset to factory settings)
              Started my Kobo up fresh and reset date/time etc.
              Launched my Kobo app and resynced. - at the same time Started up ADE
              - for the first time it actually asked me if I wanted to authorize my device (this had never happened on previous attempts)
              Said Ok
              everything works fine now.
              My thoughts -
              At some point the ADE had left some lingering presence on the Kobo enought to make it think that it was not detecting a new device.
              Wiping out the folders and digital edition files did not seem to be enough to re-trigger the authorization code to ask me  again (not that it ever had!).
              Good luck.
              • 4. Re: I cannot authorize my Kobo.
                Thanks ... it was in fact the date and time.
