3 Replies Latest reply on Jan 3, 2011 4:00 AM by Anirudh Sasikumar
    Eclipse crashes while Flash Builder starts
    4xyfenix
      Hello,
      I used Flash Builder and everything was OK, but recently I've got an annoying thing. I don't relly know what to do.
      I installed eclipse (Helios) and also installed Flash Builder Plugin. Everything worked properly.
      But something happend (don't know what exactly happend) and now when I start eclipse it shows progress bar and
      when it start loading flex builder (exact: com.adobe.flexbuilder.ui, it is shown in splash)  JVM just crushes with C++ Runtime Error (std::terminate).
      I use last java release 1.6.0_23. I tried different packages of eclipse, nothing helps.
      Please, could any kind soul help me?
      Thank you.
        • 1. Re: Eclipse crashes while Flash Builder starts
          Anirudh Sasikumar Adobe Employee
          Can you post your Eclipse log file?
          (workspace/.metadata/.log)
          Are you using the 32-bit cocoa version of Eclipse (if you are on Mac)? Flash Builder does not support 64-bit builds of Eclipse.
          • 2. Re: Eclipse crashes while Flash Builder starts
            4xyfenix Level 1
            No, I use win32 Helios & Galileo. Both fails to start.
            here the log is:
            !SESSION 2010-12-25 15:27:25.625 -----------------------------------------------
            eclipse.buildId=I20090611-1540
            java.version=1.6.0_23
            java.vendor=Sun Microsystems Inc.
            BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
            Framework arguments:  -product org.eclipse.epp.package.java.product
            Command-line arguments:  -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
            This is a continuation of log file U:\icasino\.metadata\.bak_0.log
            Created Time: 2010-12-25 15:28:44.953
            !ENTRY org.eclipse.ui 4 0 2010-12-25 15:28:44.953
            !MESSAGE Unable to create editor ID com.adobe.flexbuilder.editors.mxml.MXMLEditor: No editor descriptor for id com.adobe.flexbuilder.editors.mxml.MXMLEditor
            !STACK 1
            org.eclipse.ui.PartInitException: No editor descriptor for id com.adobe.flexbuilder.editors.mxml.MXMLEditor
            at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:598)
            at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
            at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
            at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
            at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1417)
            at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:942)
            at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
            at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
            at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
            at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
            at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
            at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
            at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
            at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
            at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
            at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
            at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
            at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
            at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
            at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
            at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
            at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
            at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
            at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
            at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
            at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
            at java.lang.reflect.Method.invoke(Unknown Source)
            at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
            at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
            at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
            !SUBENTRY 1 org.eclipse.ui 4 0 2010-12-25 15:28:44.953
            !MESSAGE No editor descriptor for id com.adobe.flexbuilder.editors.mxml.MXMLEditor
            !ENTRY org.eclipse.ui 2 2 2010-12-25 15:28:45.031
            !MESSAGE Ignored attempt to add saveable that was already registered
            !STACK 0
            org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@ca2076 from part: org.eclipse.ui.internal.ErrorEditorPart@ca2076
            at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesList.java:187)
            at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList.java:117)
            at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesList.java:289)
            at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList.java:684)
            at org.eclipse.ui.internal.PartList.partOpened(PartList.java:234)
            at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
            at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList.java:40)
            at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalPropertyChange(WorkbenchPartRe ference.java:375)
            at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:610)
            !ENTRY org.eclipse.ui 4 0 2010-12-25 15:28:46.437
            !MESSAGE Problems occurred restoring workbench.
            !SUBENTRY 1 org.eclipse.ui 0 0 2010-12-25 15:28:46.437
            !MESSAGE
            !SUBENTRY 1 org.eclipse.core.runtime 0 0 2010-12-25 15:28:46.437
            !MESSAGE OK
            !MESSAGE OK
            !MESSAGE OK
            !SUBENTRY 1 org.eclipse.ui 4 0 2010-12-25 15:28:46.437
            !MESSAGE Unable to restore perspective: Workspace - Custom.
            !SUBENTRY 2 org.eclipse.ui 0 0 2010-12-25 15:28:46.437
            !MESSAGE Problems occurred restoring perspective.
            !SUBENTRY 3 org.eclipse.ui 0 0 2010-12-25 15:28:46.437
            !MESSAGE
            !MESSAGE
            !MESSAGE
            !MESSAGE
            !SUBENTRY 2 org.eclipse.ui 4 4 2010-12-25 15:28:46.437
            !MESSAGE Could not create view: org.eclipse.wst.server.ui.ServersView
            !STACK 1
            org.eclipse.ui.PartInitException: Could not create view: org.eclipse.wst.server.ui.ServersView
            at org.eclipse.ui.internal.ViewFactory.createView(ViewFactory.java:157)
            at org.eclipse.ui.internal.Perspective.createReferences(Perspective.java:1246)
            at org.eclipse.ui.internal.Perspective.restoreState(Perspective.java:1216)
            at org.eclipse.ui.internal.WorkbenchPage$17.runWithException(WorkbenchPage.java:3205)
            !SUBENTRY 3 org.eclipse.ui 4 0 2010-12-25 15:28:46.437
            !MESSAGE Could not create view: org.eclipse.datatools.connectivity.DataSourceExplorerNavigator
            !STACK 1
            org.eclipse.ui.PartInitException: Could not create view: org.eclipse.datatools.connectivity.DataSourceExplorerNavigator
            !MESSAGE
            !STACK 1
            !MESSAGE
            !MESSAGE
            !MESSAGE
            !MESSAGE
            !MESSAGE
            !MESSAGE
            !MESSAGE
            !SUBENTRY 2 org.eclipse.ui 4 0 2010-12-25 15:28:46.437
            !MESSAGE Could not find view: org.eclipse.wst.server.ui.ServersView
            !MESSAGE OK
            !SESSION 2010-12-25 15:29:10.625 -----------------------------------------------
            eclipse.buildId=I20100608-0911
            Framework arguments:  -product org.eclipse.epp.package.jee.product
            Command-line arguments:  -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
            !ENTRY org.eclipse.ui 4 0 2010-12-25 15:29:25.796
            !STACK 1
            at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:601)
            at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
            at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1429)
            at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
            at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
            at org.eclipse.ui.internal.Workbench$31.runWithException(Workbench.java:1566)
            at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2537)
            at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
            at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
            at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
            at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
            at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
            at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
            at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
            at java.lang.reflect.Method.invoke(Method.java:597)
            at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
            at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
            at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
            !SUBENTRY 1 org.eclipse.ui 4 0 2010-12-25 15:29:25.796
            !ENTRY org.eclipse.ui 2 2 2010-12-25 15:29:25.906
            !STACK 0
            org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@385715 from part: org.eclipse.ui.internal.ErrorEditorPart@385715
            • 3. Re: Eclipse crashes while Flash Builder starts
              Looks like Eclipse is not seeing the C:\Program Files\Adobe\Adobe Flash Builder Burrito\eclipse\plugins\com.adobe.flexbuilder.mxml.editor_4.5.0.xxxxx plugin.
              Two things to try:
              1. Try starting Eclipse from the command line with -clean as an argument.
              2. Try a different workspace.
              You may also want to check if the folder C:\Program Files\Adobe\Adobe Flash Builder Burrito\eclipse\plugins\com.adobe.flexbuilder.mxml.editor_4.5.0.xxxxx folder is present.
