1 Reply Latest reply on Dec 28, 2010 5:40 PM by prariecrow
    Literati and how to work SD card issues and get it connected to ADE
    AP Summerhill Level 1
      Had difficulties being able to read Adobebook files off of SD card for the Literati reader because Literati was not seeing the Adobe ID.
      Here is how to do it.....thanks to below discussions for helping me out...
      Create Adobe ID first.
      Uninstall Adobe Digital Reader if already installed....go to your control panel/Programs/and look for Adobe Digital Reader and Uninstall.
      Connect your Literati to your PC with the USB cable.  Ensure PC sees Literati.
      Install Adobe Digital Reader once again.
      Once you install and the Adobe Digital Reader opens, a box will pop up that says it sees an ereader device and do you want to activate......say YES.
      Go to where your Adobe files are stored, which is under your harddrive, users, and the under documents (that is where you will see the Adobe Digital Reader) - open it up and you will see the book files.  Drag what you need to your SD card.  It will copy.
      Put SD card in your Literati.  Let the device read your SD card.  You might see an empty box, just click on it and it should open.  Worked for me....when you go back out you will also see the book cover.
      Hope this helps.  Took me awhile to figure it out.
        • 1. Re: Literati and how to work SD card issues and get it connected to ADE
          prariecrow
          This answer is great, thanks AP. I had Adobe reader installed and just followed this part of your instructions. I love my Literati. Thanks Adobe :-)
          " Go to where your Adobe files are stored, which is under your harddrive, users, and the under documents (that is where you will see the Adobe Digital Reader) - open it up and you will see the book files.  Drag what you need to your SD card.  It will copy.
          Put SD card in your Literati.  Let the device read your SD card.  You might see an empty box, just click on it and it should open.  Worked for me....when you go back out you will also see the book cover."
