5 Replies Latest reply on Dec 27, 2010 2:16 AM by Flex Rock
    Change images dynamically in Repeater
    Flex Rock Level 1
                I have an image control inside repeater.  I need to change the images dynmically during mouseover and mouseout.
      Regards,
      Jayagopal.
        • 1. Re: Change images dynamically in Repeater
          flex2008 Level 3
          Listen for image's mouseOver and mouseOut events and change the source in their handlers.
          • 2. Re: Change images dynamically in Repeater
            Flex Rock Level 1
            Here is my sample code .
                           xmlns:mx="library://ns.adobe.com/flex/mx" creationComplete="init()" width="100%" height="100%">
                <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                    <fx:Array id="arsImage">
                        <fx:Object label="@Embed(source='Images/images.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images1.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images2.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images4.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images5.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images6.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images7.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images8.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images9.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images10.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images11.jpg')"/>
                        <fx:Object label="@Embed(source='Images/images12.jpg')"/>
                    </fx:Array>
                </fx:Declarations>
                <fx:Script>
                    <![CDATA[
                        private var mouseOverindex:int=0;
                        private function init():void
                            imgSource.source=arsImage[0].label;
                        private function onMouseOver(event:Event):void
                            var localIndex:int=arsImage.length-1;
                            imgSource[rxImage.currentItem].source=arsImage[mouseOverindex+1].label;
                            mouseOverindex+=1;
                            if(localIndex == mouseOverindex)
                                mouseOverindex=0;
                        private function  onMouseOut(event:Event):void
                </fx:Script>
                <mx:HBox>
                    <mx:VBox horizontalScrollPolicy="auto" verticalScrollPolicy="auto">
                        <mx:Repeater id="rxImage" dataProvider="{arsImage}">
                            <mx:Image  id="imgSource" source="{rxImage.currentItem.label}" x="182" y="146"
                            mouseOver="onMouseOver(event)" mouseOut="onMouseOut(event)">
                            </mx:Image>
                        </mx:Repeater>
                    </mx:VBox>
                </mx:HBox>
            </s:Application>
            But it is not getting updated.
            Jayagopal.
            • 3. Re: Change images dynamically in Repeater
              flex2008 Level 3
              I assume for each image,you have a separate "over" image also.If so I would use this approach:
                          <fx:Object label="@Embed(source='Images/images.jpg')" label1="@Embed(source='Images/images_over.jpg')"/>
                          <fx:Object label="@Embed(source='Images/images1.jpg')" label1="@Embed(source='Images/images1_over.jpg')"/>
                         </fx:Array>
                              var image:Image = event.currentTarget as Image;
                              image.source = image.getRepeaterItem().label1;
                              image.source = image.getRepeaterItem().label;
              Let me know if that helps
              • 4. Re: Change images dynamically in Repeater
                BhaskerChari Level 4
                HI Jayagopal,
                Just replace these below two functions in your code...
                You are accessing the rxImage.currentItem which is not available after the Repeater has completed looping through the items. However if you want to get the details of the item clicked you can make use of the getRepeaterItem() function in conjunction with the current target.
                var currRepItem:Object = event.currentTaget.getRepeaterItem();
                private function onMouseOver(event:MouseEvent):void
                                var currItem:int = event.currentTarget.getRepeaterIndex();
                                //imgSource[rxImage.currentItem].source = arsImage[mouseOverindex+1].label;
                                var imgSource:Image = event.currentTarget as Image;
                                imgSource.source = arsImage[mouseOverindex+1].label;
                                mouseOverindex += 1;
                                    mouseOverindex=0;
                            private function  onMouseOut(event:MouseEvent):void
                Bhasker
                • 5. Re: Change images dynamically in Repeater
                  Flex Rock Level 1
                  Thanks Bhasker, that is what i am expecting.
                  Thanks & Regards,
                  Jayagopal.
