1 Reply Latest reply on Jun 1, 2011 8:47 AM by Monkadelic
    update record error message: Server behavior, updaterecord.js
    Alice Li Level 1
      Hello,
      I'm developing a website using PHP and MySQL on Dreamweaver CS5, Snow Leopard.
      I'm having trouble with the updateRecord Server Behavior:
      Right after selecting "Update Record" in "Server Behavior" menu, I get the following error message in a popup window:
      while executing onLoad in UpdateRecord.htm, the following javascript error(s) occurred:
      At line 687 of file "Macintosh HD:Applications:Adobe Dreamweaver CS5:Configuration:ServerBehaviors:PHP_MySQL:UpdateRecord.js." name has no properties
      After selecting "ok" in the popup window, the "Update Record" window menu opens. However, when I tried to selected the desired table from the database in the dropdown menu, the same error message/popup window appears. I clicked "ok" once again, but the "column" textarea doesn't get populated at all. But, the "Value" dropdown menu does get populated with the correct data.
      I need help asap. Please contact me if you need more information.
      Thank you so much for taking your time to read my post, hopefully you'll be able to help me.
      Best,
      Alice Li
