0 Replies Latest reply on Dec 27, 2010 12:08 PM by xinonnet
    A better example to demonstrate bugs in s:List
    xinonnet Level 1
         xmlns:mx="library://ns.adobe.com/flex/mx"
         creationComplete="changeToDp1()"
         minWidth="955" minHeight="600">
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      [Bindable]
      public var shared:String = "[Share]";
      private var dp1:ArrayCollection = new ArrayCollection( [ shared, "dp1" ] );
      private var dp2:ArrayCollection = new ArrayCollection( [ shared, "dp2" ] );
      private var dp3:ArrayCollection = new ArrayCollection( [ shared, "dp3" ] );
      public function changeToDp1():void {
      list.dataProvider = dp1;
      list.selectedItem = shared;
      public function changeToDp2():void {
      list.dataProvider = dp2;
      public function changeToDp3():void {
      list.dataProvider = dp3;
      </fx:Script>
      <s:layout>
           <s:VerticalLayout />
      </s:layout>
      <s:Button label="dp1" click="changeToDp1()" />
      <s:Button label="dp2" click="changeToDp2()" />
      <s:Button label="dp3" click="changeToDp3()" />
      <s:List id="list" />
      <s:HGroup>
           <s:Label text="list.selectedItem" />
           <s:Label text="{list.selectedItem}" />
      </s:HGroup>
      <s:HGroup>
           <s:Label text="list.selectedIndex" />
           <s:Label text="{list.selectedIndex}" />
      </s:HGroup>
      </s:Application>
      In this example, three dataProviders share a *single instance* of a String.  Since selectedItem is always set to this shared String, no matter which dataProvider is chosen, list.selectedIndex should never be -1.  In fact, "shared" is the first element in every dataProvider, therefore, selectedIndex should always be 0.
      If you keep clicking the dp Button's, you will see that selectedIndex eventually goes to -1.
      In fact, if you click on any one of the dp Button's multiple times, you will the labels change between { [Share], 0 } and { "", -1 }
