2 Replies Latest reply on Dec 28, 2010 9:55 AM by denno
    Cloned Hot Spots
    denno
      I have no idea if that was a helpful title....
      Here's what it's doing.
      www.sonnyandperley.com/bookingX.htm
      At the bottom there is a contact bar.  It is an Asset.  As written, it has a hotspot over the word "email" which links to a page in the website.  (Actually, as a test only, it is linked to the page you see it on:  bookingX.htm)
      However, the operative hotspots on that bar are apparently mirrored from the top half of the navbar below the logo at the top of the page.
      All I have to say about this is "HUH???"
      I've seen this happen before; don't remember if I managed to do anything about it.  What I consider to be "just one of those DW anomalies....."
      TIA
        • 1. Re: Cloned Hot Spots
          David_Powers Level 7
          If you looked at the code (assuming you understand it), you would be saying "Doh!" instead.
          Hotspots in image maps are defined by the <map> tag, which is separate from the image itself. The two are linked by the name attribute in the <map> tag, and the usemap attribute in the <img> tag.
          Both of your image maps have usemap="#Map" in the <img> tag, and you have two <map> tags that both use name="Map".
          Give the image map in your library item a different name, and the problem is solved.
          • 2. Re: Cloned Hot Spots
            denno Level 1
            Many thanks.  The "Map" tag -- or anchor, or whatever it is --- is, or was, beyond my knowledge of HTML.
