11 Replies Latest reply on Dec 29, 2010 5:34 PM by JeffLKS
    Getting a video player to play inside a site
    auto_ghost
      I have a site I've added a few new modules to, but the video player module just doesn't want to play at all!
      All the components load when I test the movie but none of the external data loads, and when I test the scene with all components on its own it works fine...
      I've tried a few things but, still can't get this to work, and I've even tried downloading another multi video player and it did the same thing, I don't know where I'm going wrong!
      It's all contained in a movieclip called 'bsv' and as I said works fine when I do test scene
      Can anybody help? or be able to take a look at the site if I were to upload it?
      Here's the actionscript 2 that goes with it:
      /**********---------- Config Part ----------**********/
      import cn.com.webstudio.util.*;
      Stage.scaleMode = "noscale";
      Stage.align = "TL";
      //Stage.showMenu = false;
      stop();
      /**********---------- Variable Part ----------**********/
      var xmlpath:String;
      var dataArr:Array = [];
      var curItem:Number = 0;
      //sound volume setting
      var volume:Number = 50;
      //buffer time setting
      var bufferTime:Number = 10;
      var locked:Boolean = false;
      //please set these fellowing value from external xml file.
      var autoPlayFirst:Boolean = false;
      var autoPlayAll:Boolean = false;
      var autoNext:Boolean = false;
      var mainStyleColor:Number = FFFFFF;
      var titleItem, videoItem, thumbList, controlItem, scrollItem;
      /**********---------- Function Part ----------**********/
      // Load the xml file.
      function loadXML(url:String, callback:Function) {
      var myxml:XML = new XML();
      myxml.ignoreWhite = true;
      myxml.onLoad = function(success) {
      if (success) {
      if (callback != null) {
      callback(this);
      myxml.load(url);
      if(xmlpath !== undefined ){
      loadXML(xmlpath, parseXML);
      }else{
      loadXML("xml/config.xml",parseXML);
      // parse xml data
      function parseXML(xml:XML) {
      curItem = -1;
      dataArr = [];
      var i, j, temp1, temp2, temp3;
      temp1 = xml.firstChild.firstChild.childNodes;
      // config part
      autoPlayFirst = temp1[0].firstChild.nodeValue=="true";
      autoPlayAll = temp1[1].firstChild.nodeValue=="true";
      autoNext = temp1[2].firstChild.nodeValue=="true";
      mainStyleColor = int(temp1[3].firstChild.nodeValue);
      // item data
      temp2 = xml.firstChild.childNodes[1].childNodes;
      for (i in temp2) {
      dataArr[i] = {};
      temp3 = temp2[i].childNodes;
      for (j in temp3) {
      dataArr[i][temp3[j].nodeName] = temp3[j].firstChild.nodeValue;
      init();
      function init() {
      // title item
      titleItem = this.attachMovie("titleItem", "titleItem", 1);
      titleItem._x = 68;
      titleItem._y = 21;
      // video list
      videoItem = this.attachMovie("videoItem", "videoItem", 2);
      videoItem._x = 68;
      videoItem._y = 50;
      videoItem.posX = videoItem._x;
      videoItem.posY = videoItem._y;
      videoItem.posW = videoItem._width;
      videoItem.posH = videoItem._height;
      // thumb list
      thumbList = this.attachMovie("thumbList", "thumbList", 3);
      thumbList._x = 558;
      thumbList._y = 20;
      // control item
      controlItem = this.attachMovie("controlItem", "controlItem", 4);
      controlItem._x = videoItem._x-1;
      controlItem._y = videoItem._y+videoItem._height+11;
      controlItem.posX = controlItem._x;
      controlItem.posY = controlItem._y;
      //controlItem.volBut.onPress();
      // scroll item
      scrollItem = this.attachMovie("scrollItem", "scrollItem", 5);
      scrollItem._x = thumbList._x+thumbList._width-scrollItem._width+3;
      scrollItem._y = thumbList._y+thumbList.mask._y;
      // set main style color
      setStyle();
      function setStyle() {
      wEffect.setRGB(thumbList.back, mainStyleColor);
      wEffect.setRGB(controlItem.back, mainStyleColor);
      wEffect.setRGB(titleItem.back, mainStyleColor);
      Phil
