1 Reply Latest reply on Dec 28, 2010 2:13 PM by budeborton
    Captcha has suddenly stopped working
    budeborton
      Just recently (over the past week or so) ADDT captcha has stopped working on all sites, on one server.
      • When the page is loaded, the captcha image is created on the server. I have verified the creation, and the image file looks fine.
      • The page cannot seem to "show" the image. It shows up as a broken image - however, when I right click on the broken image, the path to the image that was just created appears to be correct.
      • Obviously, because nobody can see the image - they don't know what to enter in the box.
      This is occuring on an IIS6 server running PHP 5.2.12.
      PHP has not bee updated or changed recently (ie; config files have not changed) nor has IIS6 gone through any known changes. I cannot tell if this problem occurred at a similar time as the latest Windows 2003 patch Tuesday - but I do not believe so. These were working for at least a week after those latest updates.
      Has anybody else encountered a problem with Captcha recently? Any suggestions?
        • 1. Re: Captcha has suddenly stopped working
          budeborton Level 1
          If anyone else encounters this problem (I suspect it's a Windows/IIS change) this is how I corrected it.
          1: Open "includes/common/lib/captcha/KT_Captcha.config.php" (make a backup of this file before you change it).
          2: In line 2 change this "/../../_temp/.captcha/" to this "/../../temp/captcha/"
          3: In line 3 change this "includes/common/_temp/.captcha/" to this "includes/common/temp/captcha/"
          Effectively what I have done is created a new directory structure for Captcha. Intead of a folder called "_temp" it now uses "temp". Also, instead of a folder called ".captcha" it uses "captcha".
          I figure the "dot" in front of captcha was likely the issue, but still changed them both. I'm not sure why - but these changes made it start working again.
