1 Reply Latest reply on Dec 29, 2010 4:26 PM by Wang4181
    How to disable drop after the max items in DataGrid?
    Wang4181
      I have two DataGrids, and I am able to make the drag-drop works between source_datagrid to target_datagrid, now I would like to disable the drop to target when the target_datagrid reaches the max items, but can't get it work, the drop still happened. Please point out where is wrong. Here is my code snippet:
      public function doDragEnter(event:DragEvent) : void
           var dropTarget:DataGrid = DataGrid (event.target);
           var dragObj:Array = event.dragSource.dataForFormat ("items") as Array;
           if (this.dragInitator == this.target_datagrid.id)
                //drag from target_datagrid, continue drag drop
                DragManager.showFeedback(DragManager.MOVE);
                DragManager.acceptDragDrop(dropTarget);
           else
                //drag from source_datagrid drop to target_datagrid, check if the max has reached, do nothing
                if (dropTarget.id == this.target_datagrid.id)
                     var length:int = this.targetList.length + dragObj.length;
                     //if the max is not reached, continue drag drop
                     if (length <= this.max)
                     else
                          ; //do not drag drop, but later dragDrop event still happened
      public function doDragDrop(event:DragEvent) : void
           doDragExit (event);
           //add the item to drop datagrid data provider, and remove the item from the drag datagrid data provider
      private function dragInitatorTarget (event: MouseEvent) : void
           this.dragInitator = this.target_datagrid.id;
      private function dragInitatorSource (event: MouseEvent) : void
           this.dragInitator = this.source_datagrid.id;
      public function doDragExit(event:DragEvent) : void
           dropTarget.hideDropFeedback(event);
      <mx:DataGrid id="target_datagrid" dataProvider="{this.targetList}"
           allowMultipleSelection="true"
           dragEnabled="true" dropEnabled="true" dragMoveEnabled="true"
           dragEnter="doDragEnter(event)" dragExit="doDragExit(event)" dragDrop="doDragDrop(event)"
           mouseDown="dragInitatorTarget(event)"
           editable="false" selectable="true" verticalGridLines="false" borderStyle="none"
           alternatingItemColors="[#F8F8F0, #FFFFFF]" disabledColor="0xAAA3B3"
           left="5" rowCount="16" rowHeight="20" height="83" width="100%" top="0" >
           <mx:columns>
           </mx:columns>
      </mx:DataGrid>
      <mx:DataGrid id="source_datagrid" dataProvider="{this.sourceList}"
           mouseDown="dragInitatorSource(event)"
           <mx:columns>
           </mx:columns>
      </mx:DataGrid>
        • 1. Re: How to disable drop after the max items in DataGrid?
          Wang4181 Level 1
          I had a working version.
          I found out why my code does not work, I need to call the event.preventDefault() in doDragEnter, such as:
               event.preventDefault();
                 else
                              DragManager.showFeedback(DragManager.NONE);
