4 Replies Latest reply on Jan 5, 2011 12:45 AM by ndgnc66
    prepare() method gridItemRenderer Flex Hero
    ndgnc66
      last week I installed Flash Builder Burrito to try the new spark dataGrid. I was testing the gridItemRenderer. I wanted to check something form the data and according to the results the item renderer should show three different conditions. But unfortunately I was unable to make the prepare() function work. I did it as was shown in Adobe TV (Deep Dive into Spark DataGrid) but even a trace() was not triggered.
      Is this method not working or am I making something wrong?
      Thanks for your help.
        • 1. Re: prepare() method gridItemRenderer Flex Hero
          jfb00 Level 3
          HI,
          Where is the adobe TV link?
          Prepare a sample code to show the issue, sory but nobody can guess here.
          Rgds
          Johnny
          • 2. Re: prepare() method gridItemRenderer Flex Hero
            ndgnc66 Level 1
            The Link is:
            http://tv.adobe.com/watch/max-2010-develop/deep-dive-into-the-spark-datagrid-component-and -item-renderers-/
            I created a dataGrid and inserted the following column:
            <s:GridColumn dataField="status" headerText="VP" itemRenderer="itemRenderer.FirstItemRenderer">
            which uses FirstItemRenderer as ItemRenderer. Here the code for FirstItemRenderer:
            <s:GridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                          xmlns:mx="library://ns.adobe.com/flex/mx"
            <fx:Script>
                 <![CDATA[
                      import mx.events.FlexEvent;
            // You SHOULD be able to use this method to programatically
            // change the appearance of the data in this cell. However it doesn't
            // seem to be called, yet. Probably a work in progress.
                           override public function prepare( willBeRecycled:Boolean ):void {
                                labelSatus.text = "Result";
                 /* protected function griditemrenderer1_creationCompleteHandler(event:FlexEvent):void
            </fx:Script>
                 <s:Label id="labelSatus"/>
            </s:GridItemRenderer>
            If I use the prepare method, the dataGrid is not populated with the label text "Result". But if I add a creationComplete Event to GridItemRenderer, the dataGrid column is populated with the "Result" text.
            So, my question is am I using the prepare function wrong? Can you show me how to use it to make conditional checks on the data source?
            Thanks in advance,
            • 3. Re: prepare() method gridItemRenderer Flex Hero
              kevinklin Adobe Employee
              Which build of the Flex SDK are you using? There a bug fixed where we weren't calling prepare(). Sorry for the trouble. You can grab a newer build of the SDK here: http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+Hero under the "Hero Builds" section that should have the fix in it.
              -Kevin
              • 4. Re: prepare() method gridItemRenderer Flex Hero
                ndgnc66 Level 1
                Hi Kevin,
                thanks for the information. I downloaded the build 4.5.0.18623 and it worked. But I had to install Flash Player 10.2 Beta.
                Thanks for the help.
                Nazmi
