1. Re: Pixel Bender Update fails
unique_screenname_here Dec 31, 2010 7:33 PM (in response to Nognlite)Try the directions found here:
http://download.macromedia.com/pub/labs/pixelbender/pixelbender_2.1_installer_fix_readme.p df
2. Re: Pixel Bender Update fails
Nognlite Jan 1, 2011 9:47 AM (in response to unique_screenname_here)Thanks Unique,
Yes I did try that. When I ran it it said that it failed and there was nothing else in the pdf to try if it failed.
3. Re: Pixel Bender Update fails
unique_screenname_here Jan 2, 2011 10:51 AM (in response to Nognlite)Sorry to hear it. I'll see what I can find out. In the meantime, you might try rebooting your machine and rerunning the install, to see if that gets you any further, if you have not done so already.
4. Re: Pixel Bender Update fails
Sharad Saxena Jan 12, 2011 2:10 AM (in response to Nognlite)The installer seems to be failing while installing Microsoft_VC90_CRT_x86.msi. As per your error log the msi error is 1612, so the following steps may help you in installing the update successfully -
You will find Microsoft_VC90_CRT_x86.msi in your PB 2.5 update payloads folder. Double click to install the msi manually. When it prompts for the path point to itself (i.e. Microsoft_VC90_CRT_x86.msi). If installation of Microsoft_VC90_CRT_x86.msi is successful, run the PB 2.5 update.
5. Re: Pixel Bender Update fails
Nognlite Jan 12, 2011 5:12 PM (in response to unique_screenname_here)Tried that too no success. Will try and install the msi
as stated in the last suggestion.
Pat
6. Re: Pixel Bender Update fails
Nognlite Jan 12, 2011 5:31 PM (in response to Sharad Saxena)Thank you. When I installed the msi it asked to modify, repair or remove, so I repaired and then ran the PB2.5 Toolkit that I downloaded. When all that was complete I ran the AppMgr and had 10 or 12 updates which installed with no issues. Thank you very much spsaxena.
Pat
