9 Replies Latest reply on Jan 1, 2011 8:53 AM by Gregory Lafrance
    How to set minimum size for PieChart wedge?
    Gregory Lafrance Level 6
      The following chart has one wedge that is very thin. I know it is because the data value for that wedge is very small (262) compared to the other wedge data values, but I'd like to be able to set a minimum wedge size.
      Any ideas?
      <?xml version="1.0"?>
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
        <mx:Script><![CDATA[
           import mx.collections.ArrayCollection;
           [Bindable]
           public var expenses:ArrayCollection = new ArrayCollection([
              {Expense:"Jan", Amount:2200000},
              {Expense:"Feb", Amount:4700000},
              {Expense:"Mar", Amount:2300000},
              {Expense:"Jul", Amount:262}
        ]]></mx:Script>
        <mx:Panel title="Pie Chart">
           <mx:PieChart id="myChart"
              dataProvider="{expenses}"
              showDataTips="true"
              <mx:series>
                 <mx:PieSeries
                      field="Amount"
                      nameField="Expense"
                      labelPosition="callout"
              </mx:series>
           </mx:PieChart>
        </mx:Panel>
      </mx:Application>
        • 1. Re: How to set minimum size for PieChart wedge?
          Just wondering if anyone can comment on this?
          • 2. Re: How to set minimum size for PieChart wedge?
            • 3. Re: How to set minimum size for PieChart wedge?
              IlyaG Level 1
              it is easy to implement by your own. Let's say you wan't the minimum size to be 10% so you need to calculate the new amounts like this:
              2.3M
              4.7M
              2.2M
              262
              cake = 100% = 2.3M + 4.7M + 2.2M + 262;
              min = 10% = cake * 0.1;
              dif = (min - 262) / 4;
              and now
              oldAmount = 2.3M;
              newAmount = oldAmount - dif;
              • 4. Re: How to set minimum size for PieChart wedge?
                Unfortunately, that won't work, because then the values displayed in the dataTips will be wrong.
                I need some way to affect the rendering of small wedges, without affecting the data itself.
                • 5. Re: How to set minimum size for PieChart wedge?
                  IlyaG Level 1
                  Override it, Separate your GUI from data, if there is a flex implementation for this it will act just like that.
                  • 6. Re: How to set minimum size for PieChart wedge?
                    Override what, the PieChart class?
                    How would I separate the GUI from the data?
                    Your statement "if there is a flex implementation for this it will act just like that" provides no useful information.
                    I'm looking for concrete and useful suggestions on how to actually achieve this, not high-level suggestions that really do not lead me toward a solution.
                    • 7. Re: How to set minimum size for PieChart wedge?
                      flex2008 Level 3
                      How about creating a custom item renderer for PieSeries by extending WedgeRenderer and overriding the updateDisplayList method and then modify the code there.Check the value which is going to be displayed is greater than a particular value.If not,alter the calculations used to draw the wedge and use a fixed "minimum" value.By the way I did take a look at the code in WedgeRenderer.But i could not understand it properly.
                      • 8. Re: How to set minimum size for PieChart wedge?
                        USawIt
                        This might be close enough to what you're looking for:
                        The FB 4 code is shown below:
                            xmlns:mx="library://ns.adobe.com/flex/mx"
                            minWidth="955" minHeight="600">
                            <fx:Script>
                             <![CDATA[
                                import mx.charts.HitData;
                                import mx.controls.Alert;
                                import mx.utils.ObjectUtil;
                                [Bindable] private var Amount:String = "";
                                [Bindable] private var minAmount:String = "";
                                [Bindable]
                                {Expense:"Jan", Amount:2200000, minAmount:2200000},
                                {Expense:"Feb", Amount:4700000, minAmount:4700000},
                                {Expense:"Mar", Amount:2300000, minAmount:2300000},
                                {Expense:"Jul", Amount:262, minAmount:50000}
                                private function getDataTips(hitData:HitData):String {
                                    // add percent when the user gets the DataTip
                                    var percentValue:Number = (hitData.item.Amount / 9200262) * 100;
                                    var f:int = 3;
                                    if (percentValue > 1) {
                                        f = 1;
                                    return hitData.item.Expense + ": " + percentValue.toFixed(f) + " % (" + hitData.item.Amount + ")";
                                private function getData(series:PieSeries, item:Object, fieldName:String):Object {
                                    if (item.minAmount != 50000) {
                                        return item.Amount;
                                        psExpenses.setStyle("labelPosition", "callout");
                                    } else {
                                        return item.minAmount
                                        psExpenses.setStyle("labelPosition", "none");
                            </fx:Script>
                                     dataProvider="{expenses}" dataTipFunction="getDataTips"
                                     showDataTips="true">
                                <mx:series>
                                    <mx:PieSeries id="psExpenses" nameField="Expense" dataFunction="getData"/>
                                </mx:series>
                             </mx:PieChart>
                            </mx:Panel>
                        </s:Application>
                        • 9. Re: How to set minimum size for PieChart wedge?
                          I ended up storing the original data values in an object and increasing data values that did not meet a minimum threshold in the PieChart data provider collection.
                          Then in my data tip function, I access the original values.
                          I had to jump through some hoops to get it to work, but it works.
                          Thanks for your suggestion.
