4 Replies Latest reply on Dec 30, 2010 6:46 AM by Gregory Lafrance
    Input array affected by function even though it's not returned
    Fayena Level 1
      I have it set up to call the array foalT 4 times to combine it with different results.  foalT is a multidimensional array with each element 4 elements long.   It works perfectly the first time the function is called foalTotal is correct.  The other times foalT is empty.  It appears the problem is happening when I use original.shift() and then recursively call the function but I have no idea why original is getting passed back into the foalT array.  Any help would be appreciated.
      var foalTotal:Array=Combine(foalWA,foalT);
      var foalTSC:Array=Combine(foalWASC,foalT);
      var foalTDC:Array=Combine(foalWADC,foalT);
      var foalTBC:Array = Combine(foalWABC,foalT);
      function Combine(cross:Array,original:Array):Array{
           var k:uint=0;
           var total:Array = new Array;
           trace("foalT Length:" + original.length);
           if (original.length!==0){
                for (var i:uint=0; i<cross.length; i++){
                     for (var j:uint=0; j<=3; j++){
                          total[k]= cross[i].slice();
                          total[k].push(original[0][j]);
                          k++;
                     }//end inner for
                }//end outer for
           original.shift();
           return (Combine(total,original));
           }//end if
           else
                return(cross);
      }// end fuction
