0 Replies Latest reply on Dec 30, 2010 5:33 AM by c.pfaffenbichler
    once again spot color layers
    c.pfaffenbichler Level 8
      This issue has been raised at irregular intervals previously, but once again:
      I would like Layer support for Spot Colors.
      While I would not call myself a packaging industry professional I do have to prepare package-designs for flexo-print occasionally.
      And some of the more »adventurous« graphic designers go for spot-colors for other products too, anyway, so I would see some advantages in the feature.
      Basically I would hope for something akin to a Solid Color Layer where one can paint on a Layer Mask and the resulting transparency minus the overlying layers’ opacities be transferred to the Spot Channel on the fly.
      I think Mike Ornellas has proposed something like this before.
      But I appreciate that there are difficulties connected with such a feature – at least as much as a non-programmer or -color scientist can appreciate those, I guess.
      • Some Adjustment Layers’ dialogs would have to become significantly more »elastic« to be able to encompass Spot Layers – and while I think Spot Layers should be disregarded by Hue/Saturation, Selective Color, Channel Mixer etc. Adjustments (basically everything except Curves and maybe Levels Adjustment Layers) others may disagree.
      • The simulation of mixed colors could deviate from actual, printed results more than some people expect – which might lead to customer dissatisfaction.
      • Should the Spot Color-display be based on the Color Settings Gray-setting (as it is now, if Im not mistaken) or on the CMYK-ICC-profile’s black channel or, in case of a grayscale image, on that one’s profile?
      • To what degree would the knock-out qualities of spot-layers need to be able to be customized (with a Contour/shc for example) and would they have to apply with regard to higher Layers?
      Now that if I’ve almost talked myself out of it I still hope to see some improvements with regard to spot colors in the future, like something like a Spot Channel Smart Object – a nested layered, grayscale file that has no existence in the Layers Panel and will output as a Spot Channel.
