5 Replies Latest reply on Dec 30, 2010 11:19 AM by Ned Murphy
    I need some help here...
    d0brin Level 1
      I have this .swf... where on frame 1 I import an object with AS 2.0 here is the code:
      (this is a code that makes a bitmap on pieces and when its arranged like e puzzle, it is doing something. In my case it goes to FRAME 2)
      CODE:
      import com.communitymx.CMXJigsawPuzzle;
      var puzzle:CMXJigsawPuzzle = new CMXJigsawPuzzle(this, "photo", 1, 2);
      var listener:Object = new Object();
      listener.onComplete = function() {
      gotoAndStop(2);
      puzzle.addEventListener("onComplete", listener);
      My problem is that, when it goes on frame 2, this imported puzzle, stays on the stage and my question is how to remove it? I guess with some AS code that will clear the imported thing but dunno... i need some help
        • 1. Re: I need some help here...
          What are the arguments in the constructor function?
          ->   (this, "photo", 1, 2);
          • 2. Re: I need some help here...
            d0brin Level 1
            this is at how many pieces the "photo"-bitMap is being separated
            • 3. Re: I need some help here...
              Your response doesn't answer the question.  There are 4 arguments in that constructor... what are they defining?
              • 4. Re: I need some help here...
                d0brin Level 1
                The first one the IMPORT imports this:
                import mx.events.EventDispatcher;
                import mx.utils.Delegate;
                class com.communitymx.CMXJigsawPuzzle {
                // PROPERTIES
                private var _finalPositionX:Number;
                private var _finalPositionY:Number;
                private var _pieces:Array;
                private var dispatchEvent:Function;
                public var addEventListener:Function;
                public var removeEventListener:Function;
                // CONSTRUCTOR
                public function CMXJigsawPuzzle(target:MovieClip, picture:String, rows:Number, cols:Number, width:Number, height:Number) {
                buildPuzzle(target, picture, rows, cols, width, height);
                // METHODS
                // Build Puzzle
                private function buildPuzzle(target:MovieClip, picture:String, rows:Number, cols:Number, width:Number, height:Number):Void {
                // Declare local variables used in this method
                var piece:MovieClip;
                var pieceWidth:Number;
                var pieceHeight:Number;
                var positionX:Number;
                var positionY:Number;
                var counter:Number;
                // Initialize class instance as an event
                // dispatcher
                EventDispatcher.initialize(this);
                // Attach picture from Library
                piece = target.attachMovie(picture, "mcPiece0", target.getNextHighestDepth());
                // If picture is small enough to fit and if
                // picture falls within Stage boundaries,
                // add it to pieces array; otherwise remove
                // piece and issue warning
                if (puzzleFits(piece, width, height)) {
                if (puzzleWithinBounds(piece, width, height)) {
                _pieces = new Array();
                _pieces.push(piece);
                } else {
                piece.removeMovieClip();
                trace("CMXJigsawPuzzle error:  Puzzle dimensions must fall within boundaries of Stage.");
                return;
                } else {
                trace("CMXJigsawPuzzle error:  Puzzle dimensions must be smaller than specified width and height.  If none specified, dimensions must be smaller than Stage.");
                return;
                // Initialize variables and properties
                positionX = 0;
                positionY = 0;
                pieceWidth = piece._width / cols;
                pieceHeight = piece._height / rows;
                // If target has a parent clip, use zero as
                // final position; otherwise, center final
                // position to Stage
                if (target._parent) {
                _finalPositionX = 0;
                _finalPositionY = 0;
                } else {
                _finalPositionX = (Stage.width / 2) - (piece._width / 2);
                _finalPositionY = (Stage.height / 2) - (piece._height / 2);
                // Draw and set mask on first piece
                drawAndApplyMask(piece, positionX, positionY, pieceWidth, pieceHeight);
                // Randomly position first piece and assign
                // its event handlers
                randomizePosition(piece, width, height);
                assignEventHandlers(piece);
                // Draw a container for the completed puzzle
                drawPuzzleContainer(target, _finalPositionX, _finalPositionY, piece._width, piece._height);
                // Place container behind first piece
                piece.swapDepths(target.mcContainer);
                // Attach, mask, randomly position, and assign
                // event handlers to the other pieces
                for (counter = 1; counter < (cols * rows); counter++) {
                piece = target.attachMovie(picture, "mcPiece" + counter, target.getNextHighestDepth());
                if ((counter % cols) == 0) {
                positionX = 0;
                positionY += pieceHeight;
                } else {
                positionX += pieceWidth;
                // Puzzle Fits
                private function puzzleFits(mc:MovieClip, w:Number, h:Number):Boolean {
                // Use specified width and height or Stage
                // width and height to determine fit
                return (mc._width < (w ? w : Stage.width)) && (mc._height < (h ? h : Stage.height));
                // Puzzle Within Bounds
                private function puzzleWithinBounds(mc:MovieClip, w:Number, h:Number):Boolean {
                // If puzzle is in main timeline, it is
                // guaranteed to be in bounds
                if (!mc._parent._parent) {
                return true;
                // Otherwise, determine piece's coordinates
                // relative to Stage and account for
                // possible area required by jumbling
                var point:Object = new Object();
                point.x = 0;
                point.y = 0;
                mc.localToGlobal(point);
                var bufferX:Number = 0;
                var bufferY:Number = 0;
                if (w && h) {
                bufferX = (w / 2) - (mc._width / 2);
                bufferY = (h / 2) - (mc._height / 2);
                return !((point.x - bufferX) < 0 || (point.x + mc._width + bufferX) > Stage.width || (point.y - bufferY) < 0 || (point.y + mc._height + bufferY) > Stage.height);
                // Draw Puzzle Container
                private function drawPuzzleContainer(mc:MovieClip, x:Number, y:Number, w:Number, h:Number):Void {
                // Declare local variable reference for container
                var container:MovieClip = mc.createEmptyMovieClip("mcContainer", mc.getNextHighestDepth());
                // Use Drawing API to draw a rectangle
                container.lineStyle(1);
                // Draw and Apply Mask
                private function drawAndApplyMask(mc:MovieClip, x:Number, y:Number, w:Number, h:Number):Void {
                // Declare local variable reference for mask
                var mask:MovieClip = mc.createEmptyMovieClip("mcMask", mc.getNextHighestDepth());
                mask.beginFill(0xFF0000);
                drawRect(mask, x, y, w, h);
                // Apply mask to piece
                mc.setMask(mask);
                // Draw Rect
                private function drawRect(mc:MovieClip, x:Number, y:Number, w:Number, h:Number):Void {
                // Basic Drawing API
                mc.moveTo(x, y);
                mc.lineTo(x + w, y);
                mc.lineTo(x + w, y + h);
                mc.lineTo(x, y + h);
                mc.lineTo(x, y);
                // Randomize Position
                private function randomizePosition(mc:MovieClip, w:Number, h:Number):Void {
                // Declare point object with x and y properties
                // Generate random number between zero and
                // either specified width/height or Stage
                // width/height
                point.x = Math.random() * ((w ? w : Stage.width) - mc.mcMask.getBounds(mc).xMax);
                point.y = Math.random() * ((h ? h : Stage.height) - mc.mcMask.getBounds(mc).yMax);
                // If width/height specified ...
                if (w && h) {
                // offset positioning based on specified
                // width and height, or ...
                if (mc._parent._parent) {
                point.x -= ((w / 2) - (mc._width / 2));
                point.y -= ((h / 2) - (mc._height / 2));
                } else {
                // offset based on Stage width and height
                point.x += ((Stage.width / 2) - (w / 2));
                point.y += ((Stage.height / 2) - (h / 2));
                } else {
                // ... otherwise compensate position
                // if not in the main timeline
                mc.globalToLocal(point);
                mc._x = point.x;
                mc._y = point.y;
                // Assign Event Handlers
                private function assignEventHandlers(mc:MovieClip):Void {
                // When piece is pressed, lift it above the
                // other pieces and start dragging
                mc.onPress = function() {
                this.swapDepths(this._parent.getNextHighestDepth());
                this.startDrag();
                // When piece is released, stop dragging.
                // Snap piece to final position if close
                // enough, then check if puzzle is complete
                mc.onRelease = Delegate.create(this, function () {
                mc.stopDrag();
                if (distanceBetween(mc._x, mc._y, _finalPositionX, _finalPositionY) < 6) {
                mc._x = _finalPositionX;
                mc._y = _finalPositionY;
                if (puzzleIsComplete()) {
                dispatchEvent({type:"onComplete", target:this});
                // Distance Between
                private function distanceBetween(x1:Number, y1:Number, x2:Number, y2:Number):Number {
                // Determine distance between two points with
                // Pythagorean theorem
                var x:Number = x1 - x2;
                var y:Number = y1 - y2;
                return Math.sqrt((x * x) + (y * y));
                // Puzzle Is Complete
                private function puzzleIsComplete():Boolean {
                // Loop through each piece to see if its
                // position matches the final position
                var counter:Number;
                var total:Number = _pieces.length;
                for (counter = 0; counter < total; counter++) {
                if (_pieces[counter]._x != _finalPositionX) {
                return false;
                return true;
                (This builds up a puzzle from a regular bitMAP. You are able to move the pieces and when you arrange a function is complete.)
                This defines the on complete what function to be executed:
                gotoAndStop(2);
                This as i said defines at how many pieces the bitmap is broken:
                • 5. Re: I need some help here...
                  No, I was asking about all of the arguments, not just two of them.  The code you showed answered the question for me although I only needed one line of it...
                  The first argument ("this" in your code) is the target that the puzzle is loaded into.  When you use "this", you are loading it into whatever timeline that code is in, and dynamically created content doesn't have a home fixed into a frame of the timeline it gets added to, so it will persist throughout the timeline.  You need to give it a home that is fixed to a frame in the timeline.
                  So if you manually create an empty movieclip in whatever frame the puzzle is supposed to be in and give it an instance name, say "puzzleHolder", then if you define your puzzle using....
                  var puzzle:CMXJigsawPuzzle = new CMXJigsawPuzzle(puzzleHolder, "photo", 1, 2);
                  when you move to frame 2, that puzzle SHOULD no longer be present.  (Stressing SHOULD because things aren't always what they should be)
