1 Reply Latest reply on Dec 30, 2010 9:56 PM by flex2008
    Buttons in List
    dpark1113 Level 1
      I have spark buttons in List.  I would like to trigger different task when user clicks the button, but not to trigger the list item.  Is there an "isClick" attribute on spark button?
      Thanks!
        • 1. Re: Buttons in List
          flex2008 Level 3
          1) Use a button item renderer for list
          2) Add click event handler for button
          3) In click event handler,use something like label of the button to uniquely identify the button which is clicked and based on that write the logic you want to implement.
          Here is a simple example for you:
                         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
              <s:layout>
                  <s:VerticalLayout/>
              </s:layout>
              <fx:Declarations>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <s:List width="150" height="250" itemRenderer="ButtonRenderer">
                  <s:layout>
                      <s:VerticalLayout/>
                  </s:layout>
                  <s:dataProvider>
                      <s:ArrayList>
                          <fx:String>Btn1</fx:String>
                          <fx:String>Btn2</fx:String>
                          <fx:String>Btn3</fx:String>
                          <fx:String>Btn4</fx:String>
                          <fx:String>Btn5</fx:String>
                          <fx:String>Btn6</fx:String>
                      </s:ArrayList>
                  </s:dataProvider>
              </s:List>
          </s:Application>
          Here is the ButtonRenderer class:
          <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                          autoDrawBackground="false">
              <fx:Script>
                  <![CDATA[
                      import mx.controls.Alert;
                      protected function button1_clickHandler(event:MouseEvent):void
                          if(event.currentTarget.label == 'Btn4')
                              Alert.show('You have clicked Btn4');
                          else
                              Alert.show('You have clicked some other btn');
              </fx:Script>
              <s:Button label="{data}" click="button1_clickHandler(event)"/>
          </s:ItemRenderer>
