9 Replies Latest reply on Oct 19, 2011 3:10 PM by Linda Nicholls
    Mac Fireworks Can not Run.  An Internal Error
    JEFFMACE Level 1
      I have a two day old iMac with Snow Leopard(OSX 10.6.5)    I just installed a freshly download version of Adobe CS4 Design Premium.  All of the other applications work great except for Fireworks.   The program never loads, I only see the splash screen and then the error pops up that it can not run, an internal error occurred.   It has the updater installed 10.0.4.1.   I don't know what to do..
        • 1. Re: Mac Fireworks Can not Run.  An Internal Error
          Linda Nicholls Level 4
          What kind of error message do you get?
          • 2. Re: Mac Fireworks Can not Run.  An Internal Error
            JEFFMACE Level 1
            It doesn't really give much of an error.  While the splash screen is still visible, it just says "Fireworks can not run.  An internal error occurred."
            The Dreamweaver Version 10.0 Build 4117 is also no good.  It tells me "Dreamweaver encountered problems while constructing the menus from the current menus.xml file. Pelase delete the current menus.xml file and rename menus.bak to menus.xml"   I tried to do that and it doesn't help.
            I uninstalled CS4 and used the Adobe Cleaner script to help do clear it out and reinstalled.  I get the same exact errors once reinstalled.
            I really don't know what to do.  The other apps work just fine.
            • 3. Re: Mac Fireworks Can not Run.  An Internal Error
              JEFFMACE Level 1
              I do get this type of error dump to send to Apple .  Sorry for taking up so much space here on the forum...
              Process:         Adobe Fireworks CS4 [174]
              Path:            /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/MacOS/Adobe Fireworks CS4
              Identifier:      com.macromedia.fireworks
              Version:         Adobe Fireworks CS4 version "10.0.0.495" (10.0.0)
              Code Type:       X86 (Native)
              Parent Process:  launchd [92]
              Date/Time:       2010-12-31 19:50:11.304 -0500
              OS Version:      Mac OS X 10.6.5 (10H574)
              Report Version:  6
              Interval Since Last Report:          61862 sec
              Crashes Since Last Report:           3
              Per-App Interval Since Last Report:  386 sec
              Per-App Crashes Since Last Report:   5
              Anonymous UUID:                      2573B182-7C05-4E09-8157-30FC749FB681
              Exception Type:  EXC_BAD_ACCESS (SIGBUS)
              Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000000c
              Crashed Thread:  0  Dispatch queue: com.apple.main-thread
              Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
              0   libstdc++.6.dylib             0x9715bf4e std::_Rb_tree_increment(std::_Rb_tree_node_base*) + 36
              1   com.macromedia.fireworks      0x00ee3506 0x1000 + 15607046
              2   com.macromedia.fireworks      0x00ee3534 0x1000 + 15607092
              3   com.macromedia.fireworks      0x00ee3853 0x1000 + 15607891
              4   com.macromedia.fireworks      0x005e70e4 0x1000 + 6185188
              5   com.macromedia.fireworks      0x005e7942 0x1000 + 6187330
              6   com.macromedia.fireworks      0x001f33d7 0x1000 + 2040791
              7   com.macromedia.fireworks      0x001f5076 0x1000 + 2048118
              8   com.macromedia.fireworks      0x00e6d986 0x1000 + 15124870
              9   com.macromedia.fireworks      0x00e6db1f 0x1000 + 15125279
              10  com.macromedia.fireworks      0x00e6dcba 0x1000 + 15125690
              11  com.macromedia.fireworks      0x00e6dd0a 0x1000 + 15125770
              12  com.macromedia.fireworks      0x0017d27b 0x1000 + 1557115
              13  com.macromedia.fireworks      0x0017d2bc 0x1000 + 1557180
              14  com.macromedia.fireworks      0x00e80555 0x1000 + 15201621
              15  com.macromedia.fireworks      0x00e805b2 0x1000 + 15201714
              16  com.macromedia.fireworks      0x001f4ff9 0x1000 + 2047993
              17  com.macromedia.fireworks      0x001f5040 0x1000 + 2048064
              18  com.macromedia.fireworks      0x00e6d986 0x1000 + 15124870
              19  com.macromedia.fireworks      0x00e6db1f 0x1000 + 15125279
              20  com.macromedia.fireworks      0x00e6dcba 0x1000 + 15125690
              21  com.macromedia.fireworks      0x00e6dd0a 0x1000 + 15125770
              22  com.macromedia.fireworks      0x0017d27b 0x1000 + 1557115
              23  com.macromedia.fireworks      0x0017d2bc 0x1000 + 1557180
              24  com.macromedia.fireworks      0x00e80555 0x1000 + 15201621
              25  com.macromedia.fireworks      0x00e805b2 0x1000 + 15201714
              26  com.macromedia.fireworks      0x001f4ff9 0x1000 + 2047993
              27  com.macromedia.fireworks      0x001f5040 0x1000 + 2048064
              28  com.macromedia.fireworks      0x00e6d986 0x1000 + 15124870
              29  com.macromedia.fireworks      0x00e6db1f 0x1000 + 15125279
              30  com.macromedia.fireworks      0x00e6dcba 0x1000 + 15125690
              31  com.macromedia.fireworks      0x00e6dd0a 0x1000 + 15125770
              32  com.macromedia.fireworks      0x0017d27b 0x1000 + 1557115
              33  com.macromedia.fireworks      0x0017d3da 0x1000 + 1557466
              34  com.macromedia.fireworks      0x00e71d87 0x1000 + 15142279
              35  libSystem.B.dylib             0x90cab1ff __cxa_finalize + 208
              36  libSystem.B.dylib             0x90cab114 exit + 33
              37  com.apple.HIServices          0x996cf8bb _GetApplicationDesiresAttention + 0
              38  com.macromedia.fireworks      0x007883b6 0x1000 + 7893942
              39  libPowerPlant2.dylib          0x021f3945 FW_PowerPlant::LCarbonApp::Run() + 49
              40  com.macromedia.fireworks      0x00784386 0x1000 + 7877510
              41  com.macromedia.fireworks      0x000037be 0x1000 + 10174
              42  com.macromedia.fireworks      0x000036d9 0x1000 + 9945
              Thread 1:  Dispatch queue: com.apple.libdispatch-manager
              0   libSystem.B.dylib             0x90cb2982 kevent + 10
              1   libSystem.B.dylib             0x90cb309c _dispatch_mgr_invoke + 215
              2   libSystem.B.dylib             0x90cb2559 _dispatch_queue_invoke + 163
              3   libSystem.B.dylib             0x90cb22fe _dispatch_worker_thread2 + 240
              4   libSystem.B.dylib             0x90cb1d81 _pthread_wqthread + 390
              5   libSystem.B.dylib             0x90cb1bc6 start_wqthread + 30
              Thread 2:
              0   libSystem.B.dylib             0x90cbee39 syscall + 5
              1   com.apple.OpenTransport       0x0ad45851 CarbonSelectThreadFunc + 257
              2   libSystem.B.dylib             0x90cb985d _pthread_start + 345
              3   libSystem.B.dylib             0x90cb96e2 thread_start + 34
              Thread 3:
              0   libSystem.B.dylib             0x90cba0a6 __semwait_signal + 10
              1   libSystem.B.dylib             0x90cb9d62 _pthread_cond_wait + 1191
              2   libSystem.B.dylib             0x90cbb9f8 pthread_cond_wait$UNIX2003 + 73
              3   com.apple.OpenTransport       0x0ad41d73 CarbonOperationThreadFunc + 203
              4   libSystem.B.dylib             0x90cb985d _pthread_start + 345
              5   libSystem.B.dylib             0x90cb96e2 thread_start + 34
              Thread 4:
              0   libSystem.B.dylib             0x90c8c15a semaphore_timedwait_signal_trap + 10
              1   libSystem.B.dylib             0x90cb9ce5 _pthread_cond_wait + 1066
              2   libSystem.B.dylib             0x90ce8ac8 pthread_cond_timedwait_relative_np + 47
              3   ...ple.CoreServices.CarbonCore 0x940dbecd TSWaitOnConditionTimedRelative + 242
              4   ...ple.CoreServices.CarbonCore 0x940dbc0b TSWaitOnSemaphoreCommon + 511
              5   ...ple.CoreServices.CarbonCore 0x940ffe33 TimerThread + 97
              6   libSystem.B.dylib             0x90cb985d _pthread_start + 345
              7   libSystem.B.dylib             0x90cb96e2 thread_start + 34
              Thread 5:
              0   libSystem.B.dylib             0x90c8c0fa mach_msg_trap + 10
              1   libSystem.B.dylib             0x90c8c867 mach_msg + 68
              2   ...ple.CoreServices.CarbonCore 0x941850d0 YieldToThread + 446
              3   ...ple.CoreServices.CarbonCore 0x941851d3 SetThreadState + 134
              4   ...ple.CoreServices.CarbonCore 0x9418528e SetThreadStateEndCritical + 111
              5   libPowerPlant2.dylib          0x022054e7 FW_PowerPlant::LThread::SemWait(FW_PowerPlant::LSemaphore*, long, QHdr&, unsigned char&) + 119
              6   libPowerPlant2.dylib          0x022043fd FW_PowerPlant::LSemaphore::BlockThread(long) + 61
              7   libPowerPlant2.dylib          0x02204460 FW_PowerPlant::LSemaphore::Wait(long) + 68
              8   libPowerPlant2.dylib          0x0220596c FW_PowerPlant::LThread::Cleanup::Run() + 32
              9   libPowerPlant2.dylib          0x022066ec FW_PowerPlant::LThread::DoEntry(void*) + 30
              10  ...ple.CoreServices.CarbonCore 0x9418585f CooperativeThread + 309
              11  libSystem.B.dylib             0x90cb985d _pthread_start + 345
              12  libSystem.B.dylib             0x90cb96e2 thread_start + 34
              Thread 6:
              0   libSystem.B.dylib             0x90c8c142 semaphore_wait_signal_trap + 10
              1   libSystem.B.dylib             0x90cb9cfc _pthread_cond_wait + 1089
              2   libSystem.B.dylib             0x90d0246f pthread_cond_wait + 48
              3   com.adobe.amt.services        0x204f6552 AMTConditionLock::LockWhenCondition(int) + 46
              4   com.adobe.amt.services        0x204f1995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
              5   com.adobe.amt.services        0x204f65b0 AMTThread::Worker(void*) + 20
              Thread 7:
              3   ...ple.CoreServices.CarbonCore 0x940f051e TSWaitOnCondition + 126
              4   ...ple.CoreServices.CarbonCore 0x940dbea5 TSWaitOnConditionTimedRelative + 202
              5   ...ple.CoreServices.CarbonCore 0x940d7873 MPWaitOnQueue + 250
              6   com.macromedia.fireworks      0x009a83b7 0x1000 + 10122167
              7   ...ple.CoreServices.CarbonCore 0x940bb85a PrivateMPEntryPoint + 68
              8   libSystem.B.dylib             0x90cb985d _pthread_start + 345
              9   libSystem.B.dylib             0x90cb96e2 thread_start + 34
              Thread 8:
              6   AdobeACE                      0x03bd438d 0x3ba3000 + 201613
              7   AdobeACE                      0x03bd3d85 0x3ba3000 + 200069
              8   ...ple.CoreServices.CarbonCore 0x940bb85a PrivateMPEntryPoint + 68
              9   libSystem.B.dylib             0x90cb985d _pthread_start + 345
              10  libSystem.B.dylib             0x90cb96e2 thread_start + 34
              Thread 9:
              Thread 10:
              Thread 0 crashed with X86 Thread State (32-bit):
                eax: 0x00000000  ebx: 0x00000001  ecx: 0x0a850002  edx: 0x0a850002
                edi: 0x0a857ed0  esi: 0x0a859c20  ebp: 0xbfffe968  esp: 0xbfffe968
                 ss: 0x0000001f  efl: 0x00010246  eip: 0x9715bf4e   cs: 0x00000017
                 ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
                cr2: 0x0000000c
              Binary Images:
                  0x1000 -  0x1382fdf +com.macromedia.fireworks Adobe Fireworks CS4 version "10.0.0.495" (10.0.0) <7F543F6E-FB5A-4B57-8061-65703B7FE4BD> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/MacOS/Adobe Fireworks CS4
              0x1dcd000 -  0x1e9ffe7 +AdobeAXEDOMCore ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
              0x1f53000 -  0x1fb6027 +com.adobe.PlugPlug 1.0.0.71 (1.0.0.71) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
              0x2017000 -  0x2034fef +libCurl.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/MacOS/libCurl.dylib
              0x203c000 -  0x2056fea +libChar16.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/MacOS/libChar16.dylib
              0x2061000 -  0x2083fc0 +libCoreTypes.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/MacOS/libCoreTypes.dylib
              0x209a000 -  0x20a1ffc  com.apple.carbonframeworktemplate 1.0 (1.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/NetIO.framework/Versions/A/NetIO
              0x20b1000 -  0x20b5fff +Dioxide.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/Dioxide.dylib
              0x20c1000 -  0x20c8ffd +libfwutility.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/libfwutility.dylib
              0x20d2000 -  0x2122fc7 +com.macromedia.javascript Javascript version 1.0 (1.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/Javascript.framework/Versions/A/Javascript
              0x2137000 -  0x2144fff +com.macromedia.moa Moa version 1.0 (1.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/Moa.framework/Versions/A/Moa
              0x2151000 -  0x2158fff +com.macromedia.morefiles MoreFiles version 1.0 (1.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/MoreFiles.framework/Versions/A/MoreFiles
              0x215f000 -  0x224bfef +libPowerPlant2.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/libPowerPlant2.dylib
              0x23f1000 -  0x241bffc +SiteShare.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/SiteShare.dylib
              0x2452000 -  0x2459fe3 +com.macromedia.testframework 1.0 (1.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/uwchar.framework/Versions/A/uwchar
              0x245e000 -  0x2462ffc +com.adobe.AdobeCrashReporter 2.5 (3.0.20080806) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
              0x2468000 -  0x2484fd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
              0x248f000 -  0x24a8fff +libgiff.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/libgiff.dylib
              0x24b5000 -  0x24d3fe7 +com.macromedia.png LibPNG version 1.0 (1.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/LibPNG.framework/Versions/A/LibPNG
              0x24db000 -  0x24e9feb +com.macromedia.zlib ZLib version 1.0 (1.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/ZLib.framework/Versions/A/ZLib
              0x24ee000 -  0x29ecfc3 +AdobeOwlCanvas ??? (???) <874635A0-B4F1-4387-8728-9C795AB8E905> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
              0x2b35000 -  0x2b46ffb +LogTransport2 ??? (???) <835B7B84-5A67-370B-AB39-8E448AA81FA0> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/LogTransport2.framework/Versions/A/LogTransport2
              0x2b50000 -  0x2b7fff7 +com.adobe.headlights.LogSessionFramework ??? (2.0.0.06112008) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
              0x2ba7000 -  0x2d5dff4 +com.adobe.amtlib amtlib 2.0.1.10077 (2.0.1.10077) <CB2EC3BF-6771-4DAB-BF29-6775FB6F9608> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
              0x2d94000 -  0x2f8efcf +AdobeOwl ??? (???) <75FF96D2-B036-4FF2-8738-033320CE25C2> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
              0x3009000 -  0x3099fc3 +WRServices ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
              0x321b000 -  0x32f0fdd +FileInfo ??? (???) <72E78CD5-408E-477E-AA47-2571017DC2F9> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
              0x3321000 -  0x3345ff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
              0x3358000 -  0x3372fff +AdobeBIB ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
              0x337d000 -  0x33ddfc7 +AdobeXMP ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
              0x33ec000 -  0x3a07fd7 +AdobeAGM ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
              0x3ba3000 -  0x3cb0fff +AdobeACE ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
              0x3cce000 -  0x3f6afcf +AdobeCoolType ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
              0x3ff5000 -  0x4016ff7 +AdobeBIBUtils ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
              0x4023000 -  0x4063fef +AdobeARE ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
              0x406d000 -  0x4437fef +AdobeMPS ??? (???) <277E01A3-CAC3-4FA9-A591-4BC0A5BC125A> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
              0x44c6000 -  0x4abefdf +AdobePDFL ??? (???) <7C5A530C-740F-4598-8BA2-6AFF51FD2CA2> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
              0x4c02000 -  0x5922fff +com.adobe.psl AdobePSL 11.0.0.1656 (11.0.0.1656) <A87566A2-8B8D-45B7-98FF-5396A77649C8> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
              0x5c56000 -  0x5cd2fef +AdobeScCore 3.7.0 (compatibility 3.7.0) <17A0DA14-E4D4-42B0-81B4-B75E4CB2DD8C> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
              0x5d28000 -  0x5e10fdf +AdobePDFPort ??? (???) <09C649C4-29D4-4CC6-A22A-BFFD4F751169> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
              0x5e55000 -  0x5ee22cb +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
              0x5f0f000 -  0x68bf57f +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
              0x68c2000 -  0x699123b +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dyl ib.36.0
              0x6a3a000 -  0x6b0edb7 +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
              0x6b6f000 -  0x782cfdf +com.adobe.illustrator 338 (14.0.0) <D8621BED-6312-45E6-89E1-F49896F3E87E> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
              0x8925000 -  0x8975fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <9B4C73DE-716B-4787-BB01-E1DDDC6DEA53> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
              0x8a0e000 -  0x8a5dff3 +FilterPort ??? (???) <66918FA0-9135-4C31-81DA-D4B5F8FDB798> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
              0x8afc000 -  0x8afd027 +SPBasic ??? (???) <9121C50E-FA52-4FA2-B299-AF180C3A1316> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
              0x8b01000 -  0x8edb01f +com.adobe.linguistic.LinguisticManager 4.0.0 (7863) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
              0x8f8f000 -  0x903ffeb +libCrypto.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/MacOS/libCrypto.dylib
              0x908a000 -  0x90acffc +libSSL.dylib ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/MacOS/libSSL.dylib
              0x90b9000 -  0x90f9ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
              0x9112000 -  0x91c7fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
              0x9778000 -  0x9786fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
              0x97cf000 -  0x97d0ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
              0xad3e000 -  0xad59ff7  com.apple.OpenTransport 10.6.0 (10.6.0) <ECA6FEC6-5ECD-51BA-162F-CFC43899196A> /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
              0xadab000 -  0xadf2fc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
              0xae02000 -  0xae0fff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
              0xae1d000 -  0xae1dff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
              0xbfc0000 -  0xbfdafc3  com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
              0xbfdf000 -  0xbfe4ff7  com.apple.AppleMPEG2Codec 1.0.1 (220) <6FDFF3C8-7ECE-CB74-1374-9C0230C54F78> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
              0x204d6000 - 0x20577fc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31E82904-C3C2-424E-A1AE-A5EFADBB19B8> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
              0x20655000 - 0x206aafef  com.apple.AppleProResDecoder 2.0 (223) <793BA98A-2E7D-1C39-998D-805B60034DF4> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
              0x206e2000 - 0x206fbfe7  com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
              0x208ac000 - 0x20d2efe3 +AdobeLM_libFNP.dylib ??? (???) <02E9AC76-9CC6-4974-AF05-48E737C2CC20> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/AdobeLM_libFNP.dylib
              0x20e58000 - 0x20ed2fe7  com.apple.AppleVAH264HW.component 2.0 (1.0) <B76CE5C0-7401-3B9C-CC22-369DABAAC2DD> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
              0x20f95000 - 0x20fd1fe3  com.apple.QuickTimeFireWireDV.component 7.6.6 (1756) <5723A7A8-2C99-561B-8D87-C8B0716436FA> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireD V
              0x21148000 - 0x2115aff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8D606435-1A3C-FE0B-824A-1386809FFFF5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
              0x22300000 - 0x22331fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/registration.framework/Versions/A/registration
              0x2236a000 - 0x223c6ff2 +AdobeUpdater ??? (???) <064CFAA4-1CAF-46E3-BEBF-04948641C927> /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/A/AdobeUpdater
              0x40000000 - 0x400ae030 +AdobeJP2K ??? (???) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
              0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <28F0312C-0678-159E-34E2-9A4E3DEADB20> /usr/lib/dyld
              0x9000d000 - 0x900d7fef  com.apple.CoreServices.OSServices 357 (357) <8E13E1FB-6EBD-780B-6B08-B37118311071> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
              0x900d8000 - 0x9034bfe7  com.apple.Foundation 6.6.4 (751.42) <ACC0BAEB-C590-7052-3AB2-86C207C3D6D4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
              0x90401000 - 0x9040ffe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
              0x9048f000 - 0x905c6ff7  com.apple.CoreAUC 6.04.04 (6.04.04) <050D9D16-AAE7-3460-4318-8449574F26C7> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
              0x905c7000 - 0x90675ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
              0x90676000 - 0x90676ff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
              0x90677000 - 0x906bbff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
              0x906bc000 - 0x907c8ff7  libGLProgrammability.dylib ??? (???) <8B308FAE-843F-EE76-0254-3374CBFFA7B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
              0x907c9000 - 0x907c9ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
              0x907ca000 - 0x907eafe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
              0x907eb000 - 0x90c01ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
              0x90c49000 - 0x90c8aff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <16DAE1A5-937A-1CA2-D98F-2AF958B62993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
              0x90c8b000 - 0x90e32ff7  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
              0x90ee0000 - 0x90f7dfe3  com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
              0x91026000 - 0x910a8ffb  SecurityFoundation ??? (???) <006B3166-E7E2-F763-04FC-3DD458C14F5F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
              0x910f7000 - 0x91109ff7  com.apple.CoreMediaAuthoring 0.700 (700) <446FBB01-279B-2BED-E5A8-D36241B704B1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
              0x9110a000 - 0x9111ffff  com.apple.ImageCapture 6.0.1 (6.0.1) <E7ED2AC1-834C-A44E-531E-EC05F0496DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
              0x91120000 - 0x91142fef  com.apple.DirectoryService.Framework 3.6 (621.9) <F2EEE9D7-D4FB-14F3-E647-ABD32754F557> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
              0x91159000 - 0x9158eff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
              0x91609000 - 0x91625fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
              0x91626000 - 0x91657ff7  libGLImage.dylib ??? (???) <78F59EAB-BBD4-7366-CA84-970547501978> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
              0x91658000 - 0x91693feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
              0x91694000 - 0x916a8fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
              0x91ac5000 - 0x91b3ffff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
              0x91b40000 - 0x91c44fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
              0x91c96000 - 0x91cd9ff7  libGLU.dylib ??? (???) <F8580594-0B38-F3ED-A715-CB3776B747A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
              0x91cda000 - 0x91d90ff7  libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
              0x91d91000 - 0x91d9dff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
              0x91d9e000 - 0x91d9eff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
              0x91e0e000 - 0x925fd557  com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
              0x92647000 - 0x92647ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
              0x92751000 - 0x9279afe7  libTIFF.dylib ??? (???) <AC1FC806-F7F4-174B-375F-FE5D6008666C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
              0x928ab000 - 0x928adff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
              0x928ae000 - 0x928cffe7  com.apple.opencl 12.3 (12.3) <DEA600BF-4F54-66B5-DB2F-DC57FD518543> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
              0x928d0000 - 0x92980ff3  com.apple.ColorSync 4.6.3 (4.6.3) <0354B408-665F-8B3F-87FF-64E6322276F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
              0x92981000 - 0x929e2fe7  com.apple.CoreText 3.5.0 (???) <BB50C045-25F5-65B8-B1DB-8CDAEF45EB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
              0x929e3000 - 0x92cdcfef  com.apple.QuickTime 7.6.6 (1756) <F08B13B6-31D7-BD18-DA87-A0CDFCF13B8F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
              0x92cdd000 - 0x93048ff7  com.apple.QuartzCore 1.6.3 (227.34) <CC1C1631-D8D1-D416-171E-A1683274E479> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
              0x93049000 - 0x93082ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <D6F24434-8217-DF72-2126-1953080680D7> /usr/lib/libcups.2.dylib
              0x93083000 - 0x93fd5fef  com.apple.QuickTimeComponents.component 7.6.6 (1756) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
              0x9406b000 - 0x94078ff7  com.apple.NetFS 3.2.1 (3.2.1) <A6443845-5815-2429-7649-C51A4B5E7DF9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
              0x94079000 - 0x9407bff7  libRadiance.dylib ??? (???) <10048B4A-2AE8-A4E2-21B8-C6E7A8C5B76F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
              0x9407c000 - 0x94087ff7  libGL.dylib ??? (???) <48405993-0AE9-292B-6705-C3525528682A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
              0x94088000 - 0x9408efff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
              0x9408f000 - 0x94094ff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
              0x94095000 - 0x943b5ff3  com.apple.CoreServices.CarbonCore 861.23 (861.23) <B08756E4-32C5-CC33-0268-7C00A5ED7537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
              0x943b6000 - 0x943caffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
              0x94410000 - 0x9453ffe3  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
              0x94540000 - 0x94547ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
              0x94548000 - 0x94e28ff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
              0x94e29000 - 0x94ed1ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
              0x94ed2000 - 0x94edcffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
              0x94edd000 - 0x94f3aff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
              0x94f3b000 - 0x94f3cff7  com.apple.TrustEvaluationAgent 1.1 (1) <FEB55E8C-38A4-CFE9-A737-945F39761B4C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
              0x94f4d000 - 0x94f80ff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
              0x94fd8000 - 0x9501cfe7  com.apple.Metadata 10.6.3 (507.12) <8632684D-ED4C-4CE1-4C53-015DFF10D873> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
              0x95192000 - 0x95286ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
              0x9541f000 - 0x9554bffb  com.apple.MediaToolbox 0.484.20 (484.20) <D67788A2-B772-C5DB-B12B-173B2F8EE40B> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
              0x955f9000 - 0x95679feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
              0x9567a000 - 0x95b33ffb  com.apple.VideoToolbox 0.484.20 (484.20) <E7B9F015-2569-43D7-5268-375ED937ECA5> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
              0x95b34000 - 0x95b5cff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
              0x95b9e000 - 0x95e01fef  com.apple.security 6.1.1 (37594) <1949216A-7583-B73A-6112-4D55CA5852E3> /System/Library/Frameworks/Security.framework/Versions/A/Security
              0x95e02000 - 0x95e10ff7  com.apple.opengl 1.6.11 (1.6.11) <286D1BC4-4CD8-3CD4-F723-5C196FE15FE0> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
              0x95e11000 - 0x95ea3fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
              0x96292000 - 0x96295ff7  libCoreVMClient.dylib ??? (???) <1F738E81-BB71-32C5-F1E9-C1302F71021C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
              0x96296000 - 0x96299fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
              0x9629a000 - 0x962a3ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
              0x962a4000 - 0x962e1ff7  com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
              0x96309000 - 0x96437fe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
              0x96438000 - 0x9643cff7  libGIF.dylib ??? (???) <DA5758A4-71B0-DD6E-7402-B7FB15387569> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
              0x9643d000 - 0x964eafe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
              0x964eb000 - 0x96595fe7  com.apple.CFNetwork 454.11.5 (454.11.5) <D8963574-285A-3BD6-6B25-07D39C6F67A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
              0x96596000 - 0x965dcff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
              0x96721000 - 0x96739ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
              0x9673a000 - 0x9673dffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
              0x9673e000 - 0x96764ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
              0x96765000 - 0x967d4ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
              0x967d5000 - 0x96870ff7  com.apple.ApplicationServices.ATS 4.4 (???) <ECB16606-4DF8-4AFB-C91D-F7947C26040F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
              0x96871000 - 0x96871ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
              0x96872000 - 0x9692bfe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
              0x9692c000 - 0x9692cff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
              0x96988000 - 0x969ecffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
              0x969ed000 - 0x96a11ff7  libJPEG.dylib ??? (???) <46AF3A0F-2B8D-87B9-62D4-0905678A64DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
              0x96a12000 - 0x96bcbfeb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C145139E-24C4-5A3D-B17C-809D528354B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
              0x96bcc000 - 0x96bd0ff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
              0x96c9f000 - 0x96d7afeb  com.apple.DesktopServices 1.5.9 (1.5.9) <CED00AC1-924B-0E45-7D5E-1CEA8929F5BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
              0x96d7b000 - 0x9709ffef  com.apple.HIToolbox 1.6.3 (???) <0A5F56E2-9AF3-728D-70AE-429522AEAD8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
              0x9714f000 - 0x971b9fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
              0x976da000 - 0x97727feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <8B819445-BDC3-74BD-4A7B-D650E511F0BF> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
              0x9772e000 - 0x9774dff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
              0x9776e000 - 0x9776eff7  com.apple.Carbon 150 (152) <B7AA34BE-057A-4A6B-A535-792AC1015F8E> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
              0x977de000 - 0x978bcfef  com.apple.QuickTimeMPEG4.component 7.6.6 (1756) <D01DEFB0-625A-798D-2091-5012C778951D> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
              0x978e9000 - 0x9792cff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
              0x98566000 - 0x98567ff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <BE4C2495-B758-AD22-DCC0-56A6791E948E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
              0x98608000 - 0x98608ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
              0x986b3000 - 0x986f5ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
              0x986f6000 - 0x98700fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
              0x98701000 - 0x988dcff3  libType1Scaler.dylib ??? (???) <A7AB841A-3F40-E0B8-ADDD-44014C7287C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
              0x988dd000 - 0x988eeff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
              0x988ef000 - 0x988f2ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B624AACE-991B-0FFA-2482-E69970576CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
              0x988f3000 - 0x9896efff  com.apple.AppleVAFramework 4.10.12 (4.10.12) <89C4EBE2-FE27-3160-0BD1-D0C2ED5F3605> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
              0x9896f000 - 0x98976ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <53FFD667-5E3E-4140-6A4B-0D283269DC6D> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
              0x98977000 - 0x98982ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <CB2510BD-A5B3-9D90-5917-C73F6ECAC913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
              0x989dc000 - 0x989f7ff7  libPng.dylib ??? (???) <E14178E0-B92D-94EA-DACB-04F346D7534C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
              0x98a39000 - 0x98a3dff7  libGFXShared.dylib ??? (???) <C3A805C4-C0E5-B300-430A-7E811395CB8E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
              0x98a3e000 - 0x98a7bff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
              0x98cb6000 - 0x98ce8fe3  libTrueTypeScaler.dylib ??? (???) <6E9D1A50-330E-F1F4-F93D-9ECC8A61B21A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
              0x98e4c000 - 0x98fcefe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
              0x98fcf000 - 0x990d0fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
              0x990dc000 - 0x9912cff7  com.apple.framework.familycontrols 2.0.1 (2010) <9F2045F3-DAC5-D976-F47E-27C58F80585D> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
              0x9913c000 - 0x9914cff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
              0x991c9000 - 0x992a6ff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
              0x996a2000 - 0x996a4ff7  com.apple.QuickTimeH264.component 7.6.6 (1756) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
              0x996a5000 - 0x996f6ff7  com.apple.HIServices 1.8.1 (???) <51BDD848-32A5-2425-BE07-BD037A89630A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
              0x996f7000 - 0x9978ffe7  edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
              0x99790000 - 0x9990bfe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
              0x9990c000 - 0x9991eff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
              0xb0000000 - 0xb0006ff8  com.apple.carbonframeworktemplate 1.3 (1.3.11) /Applications/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
              0xba300000 - 0xba301fe7  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <917C387A-1F4E-F72C-514D-862CF11A822C> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
              0xba500000 - 0xba501ff7  libGreekConverter.dylib 49.0.0 (compatibility 1.0.0) <AA1231CD-A969-83A5-E1EA-EABBF5F2F0EC> /System/Library/CoreServices/Encodings/libGreekConverter.dylib
              0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <B339B85B-1B6D-81D8-1281-7B8C8A517329> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
              0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <EF3E3210-927F-DB9F-4CD4-4039A2AE2F84> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
              0xbb500000 - 0xbb500ff7  libThaiConverter.dylib 49.0.0 (compatibility 1.0.0) <F867783A-58D2-3D05-2F4A-D0CD94D3F627> /System/Library/CoreServices/Encodings/libThaiConverter.dylib
              0xeab00000 - 0xeab10fe7  libConverter.dylib 169.1.0 (compatibility 1.0.0) <116CF161-A391-45BC-81B5-0954C87C8ABB> /System/Library/Printers/Libraries/libConverter.dylib
              0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
              Model: iMac11,3, BootROM IM112.0057.B00, 2 processors, Intel Core i3, 3.2 GHz, 8 GB, SMC 1.59f2
              Graphics: ATI Radeon HD 5670, ATI Radeon HD 5670, PCIe, 512 MB
              Memory Module: global_name
              AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.14.5
              Bluetooth: Version 2.3.8f7, 2 service, 19 devices, 1 incoming serial ports
              Network Service: AirPort, AirPort, en1
              Serial ATA Device: WDC WD1001FALS-40Y6A0, 931.51 GB
              Serial ATA Device: OPTIARC DVD RW AD-5680H
              USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd100000
              USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd110000
              USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd120000
              USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfa100000
              USB Device: Microsoft® 2.4GHz Transceiver V1.0, 0x045e  (Microsoft Corporation), 0x071d, 0xfa140000
              USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000
              USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0xfa111000
              USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0xfa120000
              • 4. Re: Mac Fireworks Can not Run.  An Internal Error
                Actually you couldn't have downloaded the CS4 version. CS5 is the only one availabe for download from Adobe as far as I know.
                le
                • 5. Re: Mac Fireworks Can not Run.  An Internal Error
                  JEFFMACE Level 1
                  Yes, I am still able to download CS4 because I purchased it online at adobe.com.  I just log into my account and go to my purchased products.  It allows me to download the whole 4 - 5 gb  file there.
                  • 6. Re: Mac Fireworks Can not Run.  An Internal Error
                    JEFFMACE Level 1
                    Wow, just had the worst tech support call in the history of tech support calls.  The guy on the phone didn't want to help me at all.  How do you expect people to want to keep purchasing your products.  He said to use the CS4 Fireworks updater on a CS5 fireworks install.   That sure didn't work.  Worst thing I ever heard in my life.  Very sad
                    • 7. Re: Mac Fireworks Can not Run.  An Internal Error
                      JEFFMACE Level 1
                      Quick update:
                      I created a second account on my iMac.  Logged out of my main account and then into the new account.  Fireworks (and Acrobat)  both work fine under this account, so it seems to be some kind of user account issue..  Anyone have any suggestions for this?
                      • 8. Re: Mac Fireworks Can not Run.  An Internal Error
                        mlanoue Level 1
                        I just got the same error and saw elsewhere it was related to fonts. Yesterday I moved a lot of fonts into the Adobe folder. I am not even sure which ones I moved but I suspect that is it.
                        • 9. Re: Mac Fireworks Can not Run.  An Internal Error
                          It looks like you might need to test for bad fonts with your font manager software.
