1. Re: How do you hightlight all layers in PS CS?
Noel Carboni Dec 30, 2010 4:25 PM (in response to sheana2002)You can make multiple or all layers current by clicking on one (e.g., the top one) to highlight it, then holding down the Shift key and clicking on another (e.g., the bottom one).
-Noel
2. Re: How do you hightlight all layers in PS CS?
Joprysko Dec 30, 2010 4:34 PM (in response to Noel Carboni)To add to that,
While clicking a layer then Holding shift will select all of the layers between the two click points, you can also select individual layers by pressing CTL then clicking each individual layer you want to highlight.
3. Re: How do you hightlight all layers in PS CS?
Paulo Skylar Dec 30, 2010 7:22 PM (in response to sheana2002)Just type Ctrl + Alt + A
Paulo
4. Re: How do you hightlight all layers in PS CS?
MTSTUNER Dec 31, 2010 1:37 AM (in response to sheana2002)Just to clarify from reading your previous posts, your using
photoshop cs and not cs2- cs5?
In photoshop cs (though in image ready you can) you can't select multiple
layers, you link them instead to perform operations such as transforming multiple layers
etc.
As an example, if you want to merge specific layers, in photoshop cs you would link the
layers you want to merge (instead of highlighting or selecting layers) and then choose merge linked.
In the help (Help>Photoshop Help) manual that came with cs, look under layers>linking.
MTSTUNER
Message was edited by: MTSTUNER
5. Re: How do you hightlight all layers in PS CS?
John Waller Dec 30, 2010 11:44 PM (in response to Paulo Skylar)Note: Ctrl + Alt + A selects all layers except the Background Layer
6. Re: How do you hightlight all layers in PS CS?
Noel Carboni Dec 31, 2010 3:29 AM (in response to MTSTUNER)Oops, MTSTUNER is right - I missed the reference to version CS (8.0). The Shift-click thing does not work in CS, only newer versions.
My apologies for the misinformation.
-Noel
7. Re: How do you hightlight all layers in PS CS?
Paulo Skylar Dec 31, 2010 6:53 AM (in response to John Waller)Good point ! I failed to mention that.
Paulo
8. Re: How do you hightlight all layers in PS CS?
sheana2002 Dec 31, 2010 8:54 AM (in response to MTSTUNER)Thank you for your help regarding my version of Photoshop. Thanks also for the picture - it makes it so much easier to see what to do.
