9 Replies Latest reply on Jan 3, 2011 2:09 AM by tvendhan
    Need help on selectedIndex Property
    tvendhan
      We are facing a issue in our screen which is developed using Flex Builder 3.0.
      We have Extended the Functionality of "AdvancedDataGridColumn.as" to have List of Values(LOV) editable column in it. User can add rows to the Advanced Data Grid  by Clicking on "Add Row" button.
      Actual Scenario of the problem is, When the user adds two empty rows and then enters the search crtiteria in the first row. After entering the search criteria in the first row user accidently clicks the second row. Here second row is getting populated with values whereas first row remains as it is.
      We understood that after clicking the second row, Second row becomes the active row. This is the actual cause for this issue.
      Please suggest us a solution to fix this issue.
      Thanks in Advance.
        • 1. Re: Need help on selectedIndex Property
          flex2008 Level 3
          Pls post the code where in which you are saving the data,which then leads to getting populated in the wrong row.
          • 2. Re: Need help on selectedIndex Property
            drkstr_1 Level 4
            The chances of someone finding the error in your code are a lot better if you post some.
            *edit*
            I was ninja'd
            • 3. Re: Need help on selectedIndex Property
              tvendhan Level 1
              Here is the code.
              MXML Part:
              1. eventExSelectHandler function
                   public function eventExSelectHandler(event:EventEx):void
                    cslovAC.getItemAt(adgMailTo.selectedIndex).csInChargeCode = event.params.CsInChargeCode;
                    cslovAC.getItemAt(adgMailTo.selectedIndex).csInCharge     = event.params.CsInCharge;
                    cslovAC.getItemAt(adgMailTo.selectedIndex).csMailAddress  = event.params.EmailAddress;
                    cslovAC.getItemAt(adgMailTo.selectedIndex).csCsInChargeId = event.params.CsInChargeId;
              2. Layout Part
              <lovDG:AdvancedLOVDataGridEx x="183" y="554" id="adgMailTo" designViewDataType="flat" width="731" height="90"  verticalScrollPolicy="on" visible="{japButton.selected}" dataProvider="{cslovAC}" tabIndex="13" editable="true" mouseFocusEnabled="false">
                  <lovDG:columns>
                        <lovColumn:AdvancedDataGridLOVColumn
                       headerText="担当CSコード" textAlign="left" width="150" rendererIsEditor="true"
                       dataField="csInChargeCode" lovClassification="{LOVConstants.CLASS_MAIL_TO}"
                       maxBytes="10" imeOff="true" editable="true" id="adgcMailToEmpNo"
                       eventExSelect="{eventExSelectHandler(event)}" headerWordWrap="true"
                       headerText="担当CS" textAlign="left" width="230" rendererIsEditor="true"
                       dataField="csInCharge" lovClassification="{LOVConstants.CLASS_MAIL_TO1}"
                       maxBytes="40" imeMode="{IMEConversionMode.JAPANESE_HIRAGANA}" editable="true" id="adgcMailToEmpName"
                   <ctc:AdvancedDataGridColumnEx headerText="メールアドレス" dataField="csMailAddress" id="adgcMailToAddress" textAlign="left" editable="true"      itemEditor="{new ClassFactory(scripts.AdvancedDataGridMailInput)}" headerWordWrap="true"
                   <ctc:AdvancedDataGridColumnEx headerText="チャージにCSのID" dataField="csCsInChargeId" id="adgcCsInChargeId" visible="false"/>
                  </lovDG:columns>
                 </lovDG:AdvancedLOVDataGridEx>
              Actionscript Part
              package components.lov.advancedDataGridClasses
              import components.lov.LOVConstants;
              import components.lov.renderers.LovInputExItemRenderer;
              import jp.co.ctcg.as3.controls.advancedDataGridClasses.AdvancedDataGridColumnEx;
              import jp.co.ctcg.as3.events.EventEx;
              import mx.core.ClassFactory;
              * AdvancedDataGridColumnのLOV版クラス.
              * @see mx.controls.advancedDataGridClasses.AdvancedDataGridColumn
              * @see jp.co.ctcg.xxscm_qotsbcn.common.components.LOVInputEx
              //  Events
              * データを選択された時のイベント.
              [Event(name="eventExSelect", type="jp.co.ctcg.as3.events.EventEx")]
              * 空データの状態でフォーカスアウトした時のイベント.
              [Event(name="eventEmptyFocusOut", type="jp.co.ctcg.as3.events.EventEx")]
              public class AdvancedDataGridLOVColumn extends AdvancedDataGridColumnEx
              private var lovRenderer:ClassFactory;
              private var properties:Object;
              //  Class properties
              //  Constructor
                * コンストラクタ.
                * @param columnName
              public function AdvancedDataGridLOVColumn(columnName:String=null)
                super(columnName);
                rendererIsEditor = true;
                lovRenderer = new ClassFactory(LovInputExItemRenderer);
                itemRenderer = lovRenderer;
                properties = new Object();
                lovRenderer.properties = properties;
                this.addEventListener("eventExSelectRow", eventExSelectHandler);
                this.addEventListener("eventEmptyFocusOutRow", eventEmptyFocusOutHandler);
              //  Properties
              // lovClassification
              private var _lovClassification:String;//LOV種別
                * LOV種別プロパティ.
                * @param value
              public function get lovClassification():String
                return _lovClassification;
              public function set lovClassification(value:String):void
                _lovClassification = value;
                _hideConditional = LOVConstants.HIDE_CONDITIONAL_ITEM[(int((Number(value))))];
                properties["lovClassification"] = value;
                properties["hideConditional"] = _hideConditional;
              // otherData
              private var _otherData:Object; //選択された。他その他のデータ
                * その他のデータ.
                * @param value
                  [Bindable("eventExSelectRow")]
                  [Inspectable(environment="none")]
              public function get otherData():Object
                return _otherData;
              public function set otherData(value:Object):void
                _otherData = value;
                properties["otherData"] = _otherData;
              // hideConditional
              private var _hideConditional:Object;
                * 隠し条件項目(Java側HashMap).
                * @param val Java側HashMap
              public function get hideConditional():Object
                return _hideConditional;
              public function set hideConditional(val:Object):void
                _hideConditional = val;
                properties["hideConditional"] = val;
              // prefix
              private var _prefix:String = "";//接頭語
                * 接頭語.
              public function get prefix():String
                return _prefix;
              public function set prefix(value:String):void
                _prefix = value;
                properties["prefix"] = _prefix;
              //  required
              [Bindable]
              private var _required:Boolean = false;
              private var requiredChanged:Boolean = false;
                * 必須項目の場合に指定します.背景色が黄色になります.
                * @param value true:背景色黄色,false:背景色白色.
              public function get required():Boolean
                return _required;
                * @private
              public function set required(value:Boolean):void
                _required = value;
                properties["required"] = _required;
              //  maxBytes
              private var _maxBytes:int = -1;
                * 入力できるbyte数の上限.
                * @default -1
              public function get maxBytes():int
                return _maxBytes;
                * @private
              public function set maxBytes(val:int):void
                _maxBytes = val;
                properties["maxBytes"] = _maxBytes;
              //  imeOff
              private var _imeOff:Boolean = false;
                * 日本語変換させない設定.
                * @param val
              public function get imeOff():Boolean
                return _imeOff;
                * @private
              public function set imeOff(val:Boolean):void
                _imeOff = val;
                properties["imeOff"] = _imeOff;
              //  Event handlers
              protected function eventExSelectHandler(event:EventEx):void
                dispatchEvent(new EventEx("eventExSelect", event.params, false, false));
              protected function eventEmptyFocusOutHandler(event:EventEx):void
                dispatchEvent(new EventEx("eventEmptyFocusOut", event.params, false, false));
              //  imeMode
              private var _imeMode:String = null;
                * 日本語変換させない設定.
                * @param val
              override public function get imeMode():String
                return _imeMode;
                * @private
              override public function set imeMode(val:String):void
                _imeMode = val;
                properties["imeMode"] = _imeMode;
              • 4. Re: Need help on selectedIndex Property
                flex2008 Level 3
                I have a couple of questions:
                1)When is this otherData set?
                2)What are the contents of params in EventEx?
                Pls post the relevant code for the above two to get a better understanding.
                • 5. Re: Need help on selectedIndex Property
                  tvendhan Level 1
                  Here are the answers:
                  1) I am not using OtherData property in MXML. It is just defined in ActionScript and not used anywhere in MXML.
                  2) EventEx has 4 parameters (4 Columns) csInChargeCode,csInCharge,csMailAddress and csCsInChargeId. You can very well see this four columns in Advanced Data Grid MXML part. User can select either csInChargeCode or csInCharge and depending on the selected value all the other fields will be populated.
                  Thanks.
                  • 6. Re: Need help on selectedIndex Property
                    flex2008 Level 3
                    Is it possible to post the full code,but with just one column where the issue can be reproduced?.I find it difficult to make out the reason from this.I assume it has got something to do with the place where you are dispatching eventExSelectRow event
                    • 7. Re: Need help on selectedIndex Property
                      tvendhan Level 1
                      We are using EventEx functionality to Select Corresponding Values of csInChargecode or csInCharge which user can select from LOV.
                      csInChargeCodecsInChargecsMailAddresscsCsInChargeId
                      LOV Column, If selects csInChargeCode all the other three columns will be populated with corresponding values
                      LOV ColumnNon-LOV Columnhidden Non-LOV column.
                      LOV ColumnLOV Column, If selects csInCharge all the other three columns will be populated with corresponding values
                      // ActionScript of EventEx
                      package jp.co.ctcg.as3.events
                      import flash.events.Event;
                      public class EventEx extends Event
                      //  Class constants
                      public static const EVENT_EX:String = "eventEx";
                      public static const EVENT_SELECT:String = "eventExSelect";
                      public static const EVENT_CLOSE:String = "eventExClose";
                      public static const EVENT_OK:String = "eventExOk";
                      public static const EVENT_CANCEL:String = "eventExCancel";
                      public static const EVENT_CHANGE:String = "eventExChange";
                      //  Constructor
                      public function EventEx(type:String, params:Object=null , bubbles:Boolean=false, cancelable:Boolean=false)
                        super(type, bubbles, cancelable);
                        this.params = params;
                      //  Variables
                      public var params:Object;
                      //  Overridden methods
                      override public function clone():Event
                        return new EventEx(type, params, bubbles, cancelable);
                      Thanks.
                      • 8. Re: Need help on selectedIndex Property
                        flex2008 Level 3
                        Still I cant find the portion where u are dispatching the eventExSelectRow event.Pls post the complete mxml code.
                        • 9. Re: Need help on selectedIndex Property
                          tvendhan Level 1
                          Event Dispatching is not done in MXML, It is done in "AdvancedDataGridLOVColumn.as" which was posted already. I am posting that part alone again.
                          //  Event Dispatch handlers (in AdvancedDataGridLOVColumn.as)
                          MXML Part:
                          1) eventExSelectHandler function
                          2) Assigning the above eventExSelectHandler to the AdvancedDataGridLOV Column.
                          Actual flow:
                          AdvancedDataGridLOVColumn.as ---> Imported EventEx.as (Has two Event Dispatchers in it) ---> MXML has a eventExSelectHandler as mentioned above
                          ---> eventExSelectHandler was assigned to "eventExSelect" property of AdvancedDataGridLOVColumn.
                          Thanks.
