0 Replies Latest reply on Jan 3, 2011 4:02 AM by bhmohanr
    WMI Coding Error
    bhmohanr
      I'm working on to change boot order of a machine...I'm new to WMI coding
      I'm getting this wierd error ---> D:\b.vbs(22, 1) (null): 0x80041010.Line  22 here points to "For Each objSystem in ColSystem"
      To give a try, i just commented this line 9 "For Each" to see if everything  else works fine, but still it failed in the very next line...
      This time the error was wierd again which says, D:\b.vbs(23, 2) (null):  0x80041021
      Line 23 here referrred is ,
      Set objInstance =  GetObject("WinMgmts:{impersonationLevel=impersonate,AuthenticationLevel=pktprivacy}\"  & _
      strComputerName & "/" & strNameSpace & ":" &  strClassName & "=" & _
      Chr(34) & intKey & Chr(34))
      Please help me in fixing this as the errors above aren't in detail and i'm  struck with my deliverables now...
      Below is the complete code ...
      Dim strNameSpace
      Dim strComputerName
      Dim  strClassName,intKey
      strComputerName = "."
      strNameSpace =  "root/Dellomci"
      strClassName = "Dell_BootDeviceSequence"
      intKey = 0
      'Set objWMIService =  GetObject("winmgmts:{impersonationLevel=impersonate,AuthenticationLevel=pktprivacy}\"  & strComputerName & "\root\dellomci")
      'Set objWMIService =  GetObject("winmgmts:" _
      '& "{impersonationLevel=impersonate}!\\"  _
      '& strComputer & "\root\cimv2")
      'Set objWMIService =  GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" _ &  strComputer & "\root\default:StdRegProv")
      Set WshShell =  WScript.CreateObject("WScript.Shell")
      Set SWBemlocator =  CreateObject("WbemScripting.SWbemLocator")
      Set objWMIService =  SWBemlocator.ConnectServer(strComputer,"\root\CIMV2")
      Set ColSystem=objWMIService.execquery ("Select * from  Dell_BootDeviceSequence")
      strDeviceName =  objInstance.Properties_.Item("BootDeviceName").Value
      strDeviceOrder =  objInstance.Properties_.Item("BootOrder").Value
      strDeviceStatus =  objInstance.Properties_.Item("Status").Value
      intKey = intKey + 1
      strMsg = strDeviceName
      strMsg = strMsg & vbCRLF & "Boot  Position: " & strDeviceOrder
      strMsg = strMsg & vbCRLF & "Boot  Status: "
        If strDeviceStatus = "1" Then
         strMsg = strMsg &  "On"
        Else
         strMsg = strMsg & "Off"
        End If
      If strDeviceName = "Internal HDD" Then
        Else
        End If
      End If
      If strDeviceName = "Hard-Disk Drive C:" Then
        Else
        End If
      End If
      If strDeviceName = "Onboard SATA Hard Drive" Then
        Else
        End If
      End If
      WScript.Echo strMsg
      Next
      Regards,
      Bharath M
