2 Replies Latest reply on Jan 3, 2011 10:25 AM by UGA_Bulldawg
    Error Getting Local Java Environment SetUp
    UGA_Bulldawg
      I checked out the code from the trunk directory and am trying to attempt to get my local environment setup so I can make my own rules; however, when I initially run "MVN package" per the instructions I receive the following error.  Is this swc required or should I remove the dependency for it?
      Thanks!
      Andrew
      [INFO] ------------------------------------------------------------------------
      [ERROR] BUILD ERROR
      [INFO] Failed to resolve artifact.
      Missing:
      1) com.adobe.cairngorm:event-source:swc:1.1
        Try downloading the file manually from the project website.
        Then, install it using the command:
            mvn install:install-file -DgroupId=com.adobe.cairngorm -DartifactId=event-
      source -Dversion=1.1 -Dpackaging=swc -Dfile=/path/to/file
        Alternatively, if you host your own repository you can deploy the file there:
            mvn deploy:deploy-file -DgroupId=com.adobe.cairngorm -DartifactId=event-so
      urce -Dversion=1.1 -Dpackaging=swc -Dfile=/path/to/file -Durl=[url] -Drepository
      Id=[id]
        Path to dependency:
              1) com.adobe.ac:flex-pmd-flex-lib:swc:1.3-SNAPSHOT
              2) com.adobe.cairngorm:event-source:swc:1.1
      1 required artifact is missing.
      for artifact:
      from the specified remote repositories:
        flexmojos-repository (http://repository.sonatype.org/content/groups/public/),
        central (http://repo1.maven.org/maven2),
        dist.codehaus.org (http://dist.codehaus.org/),
        nexus.codehaus (https://nexus.codehaus.org/content/repositories/releases),
        maven2-repository.dev.java.net (http://download.java.net/maven/2/),
        apache (http://cvs.apache.org/repository/),
        flex-mojos (http://repository.sonatype.org/content/groups/flexgroup)
