1 Reply Latest reply: Jan 3, 2011 8:26 PM by Chris Cox RSS
    Disable sharpening for transform/rotate image
    n8turepix Community Member
      I am doing calibration of scanners, and this involves scanning a test target film (which is never perfectly aligned) and then rotating the image slightly so it's properly aligned in the horizontal and vertical directions.  It is a requirement that the color values of the image not be altered when the image is rotated.  Photoshop's rotation transformation applies default sharpening which cannot be disabled, and this causes clipping and other changes in the color values of the image data.
      It would be most helpful to provide a way to disable sharpening of the image data when it's rotated.  Without it, the final color profiles are not accurate.
      -Chris.
        • 1. Re: Disable sharpening for transform/rotate image
          Chris Cox Adobe Employee
          You can do that by changing the interpolation method in preferences.
          In most cases, the image does need some sharpening in the interpolation method when rotating (otherwise it ends up looking fuzzy).
          Technically, that is impossible except for 90 degree rotations.    Any interpolation will change the color values.
