4 Replies Latest reply on Jan 4, 2011 10:01 PM by nicoladinh
    SWFLoader.load() and sizing problem
    nicoladinh
      hi guys,,
      this is my mxml:
      <mx:SWFLoader id="my_swf" source="blah_blah.swf" width="100" height="100"/>
      the actual size of "blah_blah.swf" is 200x200,
      when i want to replay the swf, i call this code:
      my_swf.load();
      but this is the point making problem, flex resets back my clip to
      the original size which is 200x200
      note that without calling "my_swf.load();" the clip showing correctly 100x100
      please guide me to learn why.....
        • 1. Re: SWFLoader.load() and sizing problem
          learner_doug Level 1
          I resize my external swfs with scaleX and scaleY to chang the size.  Not sure if this is what you are after.  But I use the mx:SWFloader most of the time and call the swfs with swfLoader.load("bla_bla.swf");
          Perhaps this helps a bit.
          • 2. Re: SWFLoader.load() and sizing problem
            nicoladinh Level 1
            it seems like "my_swf.load();" will set my_swf to null
            because of lacking file path, that could be the problem?
            • 3. Re: SWFLoader.load() and sizing problem
              Might need to add a path to your URL.  From your example, I'm not sure how you are getting the actual swf to load - I don't see a reference to it, but here is an example that includes all the pieces you need.
              1. with a
              <mx:SWFLoader id = "loader" scaleX="someValue" scaleY="someValue" />
              somewhere in your application/component
              2.  The following code in your <mx:Script> section:
              some function(event:SomeEvent):void  //  note that "SomeEvent" needs to be specific, either a MouseEvent (if mouse click), or other real Flex Event)
              loader.load("path/bla_bla.swf");
                   loader.x = someValue;  //places the swf where you want it
                   loader.y = someValue;  //places the swf where you want it
              • 4. Re: SWFLoader.load() and sizing problem
                nicoladinh Level 1
                my path to the swf is correct as it is shown on the stage,
                however, what i wonder is why after calling "my_swf.load()"
                the swf on stage is resized back to the original size
                code:
                my_swf.load(); //it resizes itself back to original size 200x200 here
