3 Replies Latest reply on Jan 5, 2011 7:31 AM by jfb00
    Disable row edit
    jfb00 Level 3
      Hi All,
      I found this:
      http://blog.classsoftware.com/index.cfm/2007/6/11/Flex-Datagrid-Edit-Cell-on-Row-Click
      How can I do the other way around?
      I have a column that is enable for edit but base in some condition I want to disable the edit for entire row in my datagrid.
      Johnny
        • 1. Re: Disable row edit
          Flex harUI Adobe Employee
          You can block editing via the ITEM_EDIT_BEGINNING event.
          • 2. Re: Disable row edit
            jfb00 Level 3
            How Alex?
            I add ITEM_EDIT_BEGINNING event in my advanced datagrid to call a function like:
            private function disableRow(event:AdvancedDataGridEvent):void{
               if(event.dataField=="FIELD_03"){
                   var temp:String = event.itemRenderer.data["FIELD_02"]; //Here I capture value of my 2nd column
                   if (temp == "MyCondition")
                      //Here I want to block the editing
            Thanks for your help and reply.
            Johnny
            • 3. Re: Disable row edit
              jfb00 Level 3
              I go it.
                 if(event.dataField==FIELD_03){
                     var temp:String = event.itemRenderer.data[FIELD_02]; //Here I capture value of my 2nd column
                     if (temp == MyCondition)
                        event.preventDefault();
