6 Replies Latest reply on Jan 12, 2011 9:25 AM by pkrk
    Graphics
    pkrk
      I am building a script that will in part loop through and check all the Graphics in the document for a certain swatch.
      It works correctly for "Image" when I check for fillColor, strokeColor and gapColor... but not much else.
      I'm wondering if it is even possible to check for the embedded swatch in a placed PDF, EPS....?(Will I have to take it a step further and create clipping paths ?)
      Below is a sample of what works with Image if the color is set in Indesign when looping through all the Graphics.
      myGraphicsFillColor = myGraphics[graphCount].fillColor.name
      Thank you in advance!
        • 1. Re: Graphics
          pkrk Level 1
          I'm just rephrasing my question and hoping I have better luck on this one.
          If there is an EPS or a PDF that has been placed in an Indesign document, is there a way through scripting to know what swatches it uses?
          • 2. Re: Graphics
            Harbs. Level 6
            Not that I know of.
            If you are really desperate you might be able to use cross app scripting to open it in Illustrator and find out there...
            Harbs
            • 3. Re: Graphics
              pkrk Level 1
              Trying to avoid that as it probably entails a lot more than I can chew.
              Thanks for your response!
              • 4. Re: Graphics
                [Jongware]-9BC6tI Level 4
                Thinking outside the box: what if you create a new document, remove all swatches (only Black and Paper and None would be left, because you can't remove these), paste your graphic in it and see what swatches get added?
                • 5. Re: Graphics
                  Muppet Mark-QAl63s Level 4
                  I suppose a lot would depend on the 'graphic' in question, it's type and it's 'creator'. I get a reasonable amount of milage from reading the filehead data from such files… Im on a mac so I can filter files before hand based on their creators. That said this works with my CS2 illustrator files…
                  var aiGraphic = new File('~/Desktop/Colors/CMYK_Doc_PMS.ai');
                  var aiSpots = graphicSpots(aiGraphic);
                  alert(arrayToString(aiSpots,'\r'));
                  function graphicSpots(f) {
                       var colorList = Array();
                       f.open('r');
                       while (!f.eof) {
                            var line = f.readln();
                            if (/%%DocumentCustomColors:/.test(line)) {
                                 colorList.push(line.substring(25, line.length-1));
                                 var nextLine = f.readln();
                                 while (/^%%CMYKCustomColor:/.test(nextLine) == false) {
                                      colorList.push(nextLine.substring(5, nextLine.length-1));
                       f.close();
                       return colorList;
                  function arrayToString(arr,d) {
                       return arr.join(d);
                  • 6. Re: Graphics
                    pkrk Level 1
                    Thanks. I'm trimming the fat off the rest of my script at the moment and will revisit the topic shortly. I have some questions but I want to make sure I know more about what I'm asking before I waste your time.
                    Thanks again!
