3 Replies Latest reply on Jan 27, 2011 3:44 PM by Blue Strike
    Check value once swf is loaded
    juresti Level 1
      There are 50 movies loaded sequentially. From Q1 thru Q29 I want to attach a particular title (mc) to the main movie and then for Q30 thru Q40 another and so on. The file is on an Learning Management Sytem so I'm using SCORM code.
      A movie is loaded in a clip in the main movie. A bookmark is set.
      _parent.saveBookmark("Q1");
      _parent.test1();
      The main move has this code on the first frame:
      function saveBookmark(loc:String) {
         scorm.set("cmi.core.lesson_location", loc);
         scorm.save();
      function getBookmark():String {
        return scorm.get("cmi.core.lesson_location");
      var bookmark:String = getBookmark();
      var mySubstring:Number = Number(bookmark.substr(1));
      //There's a Q in my bookmark!
      if(bookmark.indexOf("Q") !== -1 && bookmark !== undefined){
         //add the underscore after the Q to match filename
         bookmark = bookmark.split("Q").join("Q_");
         swfURL = bookmark +".swf";
         trace(swfURL);
      function testi() {
          trace(mySubstring);
          trace("ahhh");
      if (mySubstring <= 29 && isNaN(mySubstring) == true && bookmark !== undefined){
          attachMovie("title_foundational", "ttl_foundational", 1, {_x: 217, _y: 5});
      startPreload(swfURL);
      I'm lost.
        • 1. Re: Check value once swf is loaded
          juresti Level 1
          I want to do 4 things check to see if there is a bookmark, add if the number after the Q is <= 29 greater than 29 less than 30 do something, greater than 30 do something else, and finally add an underscore to the value of the variable bookmark.
             trace(swfURL);
          • 2. Re: Check value once swf is loaded
            juresti Level 1
            This worked:
            if(bookmark.indexOf("Q") !== -1 && bookmark !== undefined && mySubstring <= 24){
                trace(mySubstring);
               trace(swfURL);}
            else if   (bookmark.indexOf("Q") !== -1 && bookmark !== undefined && mySubstring > 25 && mySubstring < 37) {
                trace(mySubstring);
                attachMovie("title_mills", "ttl_mills", 1, {_x: 217, _y: 5});
               trace(swfURL);}
            else if   (bookmark.indexOf("Q") !== -1 && bookmark !== undefined && mySubstring >= 37) {
                trace(mySubstring);
                attachMovie("title_misc", "ttl_misc", 1, {_x: 217, _y: 5});
               trace(swfURL);}
            • 3. Re: Check value once swf is loaded
              Blue Strike
              Hi, I noticed at the top of your code, you have _parent.test1 and at the bottom of your code, you call function testi<------ not sure if this helps..!!
              _parent.test1();
              // The main move has this code on the first frame:
              scorm.set("cmi.core.lesson_location",loc);
              scorm.save();
              if (bookmark.indexOf("Q") !== -1 && bookmark !== undefined) {
              swfURL = bookmark+".swf";
              trace(swfURL);
              function testi() {
              trace(mySubstring);
              trace("ahhh");
              if (mySubstring<=29 && isNaN(mySubstring) == true && bookmark !== undefined) {
                attachMovie("title_foundational","ttl_foundational",1,{_x:217, _y:5});
