4 Replies Latest reply on Jan 11, 2011 7:22 AM by Claudiu Ursica
    Transforming data returned from a JSON service into my actual model objects
    JoshBeall
      Hi All,
      I've got some model object in my application that have definite types (e.g., Person, Address, Membership, etc.).
      I'm working on the service that will handle communication from the Flex client and the server.  Now, when I get a JSON object back from the server, it is going to have a different type than my model objects--either it will just be a dynamic object with properties mapping to all the data in the JSON string, or I might use Flex's tools to create a strongly typed result.  Either way, the result of the service call will be different than the type of my model classes in the Flex app.
      What is the best way to suck in the data from the results of my service call and populate my model objects?  Do I have to go field by field, like this:
      model.firstname = result.firstname;
      model.lastname = result.lastname;
      model.email = result.email;
      And so on?  Or, is there a way in ActionScript to say "every field on the result object, assign to the corresponding field on the model object?"
        -Josh
        • 1. Re: Transforming data returned from a JSON service into my actual model objects
          Claudiu Ursica Level 4
          I used this a while ago to translate objects. Found it on some blog don't
          remeber who deserves the credit for it ...
          package
              import mx.collections.ArrayCollection;
              public class ObjectTranslator
                  import mx.utils.ArrayUtil;
                  import flash.utils.*;
                  import mx.core.DeferredInstanceFromClass;
                  public static function translateArrayObjects(arrayOfObjects:Array,
          translateToClass:Class, upperCaseFromVar:Boolean=false):Array
                      // describeType describes a class and all of its properties
                      var classInfo:XML = describeType(translateToClass);
                      // get the class name, in order to instantiate more classes
                      var className:String = classInfo.@name;
                      var i:Number = new Number();
                      var returnArray:Array = new Array();
                      // get a reference to the class to create new classes
                      var classRef:Class = Class(getDefinitionByName(className ));
                      var tempObj:Object = new classRef();
                      if (arrayOfObjects != null)
                          for (i=0; i <arrayOfObjects.length; i++)
                              // for each new object, create a new class of the class type
          that was passed in.
                              tempObj = new classRef();
                              // send it off to translateObject function. send it the
          class to populate
                              returnArray.push(translateObject(arrayOfObjects[i], tempObj,
          classInfo, upperCaseFromVar));
                      return returnArray;  // return the translated array
                  public static function translateObject(translateFrom:Object,
          translateTo:Object, classInfo:XML = null, upperCaseFromVar:Boolean =
          false):Object
                      var vType:String;
                      var vName:String;
                      var fromName:String;
                      // if class information has already been sent in, we don't need to
          re-fetch it.
                      if (classInfo == null)
                          classInfo = describeType(translateTo);
                      for each (var v:XML in classInfo..variable)
                          try
                              // xml values don't exactly match the variable name unless
          it knows for sure it's a string
                              vName = v.@name;
                              vType = v.@type;
                              if (upperCaseFromVar)
                                  fromName = vName.toUpperCase();
                              else
                                  fromName = vName;
                              // check to see if the untyped object has a property that
          matches the typed property
                              // if it does, then translate it.  if not, skip it.
                              // this is done to maintain integrity with the application
          and the internal classes.
                              // internal classes are static (unless they've been made
          dynamic) an error will result if
                              // and unknown variable is set in it.
                              if (translateFrom.hasOwnProperty(vName) &&
          translateFrom[vName] != null)
                                  // Only need to check for a few types here. variables
          should come across
                                  // in a limited number of base object types, ie numbers,
          ints, dates, strings, etc.
                                  // anything else is assumed to be a class and will be
          sent for translation as well.
                                  // the one case that is not dealt with here is when an
          array of objects underneath
                                  // an array of objects.  This can be theoretically set
          up, but there's no clear
                                  // an array of objects has to be a special type of
          array, which in most cases only limits
                                  // the objects that can be store in it to a specific
          class.  the simplest way around
                                  // this is to send back a simple array of untyped
          objects which can then be translated
                                  // at the point that they are needed.
                                  switch (vType)
                                      case "Array":
                                          // in beta 3 SOAP sequences were typed as arrays
          by FLEX.
                                          if (translateFrom[vName] is ArrayCollection)
                                              translateTo[vName] =
          translateFrom[fromName].source;
                                          else if (translateFrom[fromName] is Array)
          translateFrom[fromName];
                                          break;
                                      case "mx.collections::ArrayCollection":
                                          // in the GA release it looks like SOAP
          sequences are
                                          // typed as arrayCollections.  Support has been
          left in for both
                                          // types... just in case, so this function can
          be used for both types.
                                          if (translateFrom[fromName] is ArrayCollection)
                                              translateTo[vName].source =
                                          break;
                                      case "Number" :
                                          // sometimes numbers come across as a
          complexString.  this can
                                          // cause a mess at runtime if there is a need to
          check against a
                                          // simple number type.
                                          translateTo[vName] = new
          Number(translateFrom[fromName]);
                                          break;
                                      case "int" :
                                          // ditto for ints
          int(translateFrom[fromName]);
                                          break;
                                      case "uint" :
                                          // ditto for uints
          uint(translateFrom[fromName]);
                                          break;
                                      case "Date":
                                          // ditto for dates.  what's nice about this
          function is that with a little
                                          // work, dates can automatically be transfered
          from a UTC format or a string
                                          // format (used sometimes for easy transport)
          into an actual date format
                                          // which should be easier to use.
                                          if (translateFrom[fromName] is Date)
                                          else if (translateFrom[fromName] is String)
          parseDateFromString(translateFrom[fromName]);
                                          else if (translateFrom[fromName] is Number ||
          translateFrom[fromName] is int ||    translateFrom[fromName] is uint)
          parseUtcDate(translateFrom[fromName]);
                                          break;
                                      case "Boolean":
                                          // Booleans get typed as a complexString
          sometimes too.
          getBooleanValue(translateFrom[fromName]);
                                          break;
                                      case "String":
                                          break;
                                      case "Object":
                                          translateTo[vName] = translateFrom[fromName];
                                          break;
                                      default:
                                          // assuming that anything that makes it here is
          a sub class...
                                          // send it to the this function again to decode
          it...
                                          var definition:Class =
          getDefinitionByName(vType.replace(/::/, ".")) as Class;
          translateObject(translateFrom[fromName], new definition());
                                          break;
                          catch (e:Error)
                              // do nothing // we will loose data, but our app will stay
          in tact;
                              //if (translateFrom.hasOwnProperty(v.@name))     {
                              //    translateTo[v.@name] = translateFrom[v.@name];
                              trace("an error occured in ObjectTranslator. The following
          fields were not captured correctly - to:" + vName + "  from:" + fromName);
                              trace(translateTo[vName]);
                              trace(translateFrom[fromName]);
                      return translateTo;
          translateArrayCollection(collection:ArrayCollection, translateToClass:Class,
          upperCaseFromVar:Boolean=false):ArrayCollection
                      // this is a convenience function.  in the GA release of FLEX 2,
          objects are now coming back as
                      // array collections.  if an array collection is expected, this
          function will check to make sure
                      // that it is not null.  it returns a completely new collection,
          which may or may not be what is desired.
                      var returnCollection:ArrayCollection = new ArrayCollection();
                      if (collection != null)
                          if (collection.length > 0)
                              returnCollection.source =
          translateArrayObjects(collection.source, translateToClass, upperCaseFromVar);
                      return returnCollection;
          translateArrayCollectionAsArray(collection:ArrayCollection,
                      // that it is not null.  it returns a completely new Array, which
                      var returnArray:Array = new Array;
                          if (collection.length > 0 )
                              returnArray =
          translateArrayObjects(collection.source,translateToClass,upperCaseFromVar);
                      return returnArray;
                  public static function parseUtcDate(utcNumber:Number):Date
                      var returnDate:Date;
                      // there should be a minimum length here for a valid utc Date
                      if (utcNumber.toString().length > 6)
                          returnDate = new Date;
                          returnDate.setTime(utcNumber);
                      return returnDate;
                  public static function parseDateFromString(dateString:String):Date
                      // check to see if we have a utc date as a string
                      // guessing that dateString should be at least 6 chars long in order
          to be
                      // considered a viable date.... this could be a problem though,
          because theoretically,
                      // a time of zero should still be valid.
                      if (dateString.length > 6 && parseInt(dateString).toString().length
          6)
                          // we probaly have a utc date here
                          returnDate = parseUtcDate(parseInt(dateString));
                      else
                          //  we didn't get a utc date so let's try to parse it...
                          returnDate = parseUtcDate(Date.parse(dateString));
                      return returnDate;
                  public static function getBooleanValue(bValue:Object):Boolean
                      var returnBoolean:Boolean = false;
                      var stringBoolean:String = bValue.toString().toLowerCase();
                      if (stringBoolean == "true" || stringBoolean == "yes" ||
          stringBoolean == "1" || stringBoolean == "-1")
                          returnBoolean = true;
                      return returnBoolean;
                  public static function clone(source:Object):*
                      var myBA:ByteArray = new ByteArray();
                      myBA.writeObject(source);
                      myBA.position = 0;
                      return(myBA.readObject());
          usage:
          var response:CustomObjectResponse =
          ObjectTranslator.translateObject(event.result, new CustomObjectResponse()) as
          CustomObjectResponse;
          HTH,
          C
          • 2. Re: Transforming data returned from a JSON service into my actual model objects
            JoshBeall Level 1
            What is this line doing?
            I looked through the describeType XML and I can't find "variable" anywhere, so I'm not sure what that's supposed to do.
            I do know that when the Flash player gets to this line, it skips the entire for each loop, I'm assuming because it can't find an XMLList when it evaluates the expression "classInfo..variable"...? If I put a watch on that expression, I get an empty XMLList.
              -Josh
            • 3. Re: Transforming data returned from a JSON service into my actual model objects
              JoshBeall Level 1
              Maybe the describeType XML has changed since you wrote that?  I tried changing it to classInfo..accessor and that seemed to do the trick.
                -Josh
              • 4. Re: Transforming data returned from a JSON service into my actual model objects
                I haven;t used that in the last 6 months or even more. When I used it was with
                flex3. I put up a quick example which I have attached to the email. Hope the
                attachment will upload if not I can email it to you. Your issue might be due to
                the fact that you use getters setters instead of public variables for your value
                objects. Check the example and you will see that the variable show in the xml
                instead of the accessor. Feel free to enhance it I did not write it in the first
                place. Also if you look in there the code does not catters for the ArrayList
                type.
                If/when have the time I might be updating it.
                C
