3 Replies Latest reply on Jan 15, 2011 9:08 AM by 62316e
    Making One Object Move, both players see it fine, but very slow.
    vinceaction
      Hi there,
      I am simply trying to send one object (movieClip) move from the left side of the stage to the right side. I am able to accomplish this by using the following very simple code:
      /////////////////////////////CODE///////////////////////////////////////////////////////// ///////////////////////////////////////////////////////////////////
      //PRESSING RIGHT, MAKING BOX MOVE
      public function pressingRightMakingBoxMove(e:KeyboardEvent) {
                box.x += 3;
                moveBox.sender = netGroup.convertPeerIDToGroupAddress(netConnection.nearID);
                moveBox.user = "" + netConnection.nearID;
                moveBox.xx = box.x;
           netGroup.post(moveBox);
      public function netStatus(event:NetStatusEvent) {
           switch(event.info.code){
                case "NetConnection.Connect.Success":
                     setupGroup();
                break;
                case "NetGroup.Posting.Notify":
                     receiveBoxMovement(event.info.message);
                break;
      public function receiveBoxMovement(moveBox:Object):void{
            box.x = moveBox.xx;
      ////////////////////////////////////////////////////////////////////////////////////////// ENDCODE//////////////////////////////////////////////////////////////
      It works fine, the box moves on both screens, but you can obviously tell there is latency. Should I be sending movements through an Object? Perhaps there is a quicker way, sending it through strings or text? Definitely not acceptable over UDP.
      Thank you
