5 Replies Latest reply on Apr 5, 2011 10:09 PM by $Nith$
    Searching task from API by process instance id
    hkho Level 1
      Hi, I am having problem retrieving tasks by process instance id throught API.
      I've look at the help, http://help.adobe.com/en_US/livecycle/9.0/programLC/help/index.html,
      it got sample code to retrieve tasks, it retrieve all tasks by process name, but I need to retrieve only tasks belong to a process instance id.
      how can i achieve this? any help is appreciated, thanks.
      hkho
        • 1. Re: Searching task from API by process instance id
          $Nith$ Level 4
          The following code may retrieve the tasks for a specific process instance.
          ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
          TaskManagerQueryService queryManager = TaskManagerClientFactory.getQueryManager(myFactory);
          TaskSearchFilter filter = new TaskSearchFilter();
          filter.setServiceName("MortgageLoan - Prebuilt");
          filter.addCondition("procVar.id", Operator.EQUALS, new Long(556677)); // where 556677 is your process Instance Id
          filter.setAdminIgnoreAllAcls(true);
          List result = queryManager.taskSearch(filter);
          Note:
            -> I dint test this code;
            -> You may have to make some corrections if its not working
            -> The code is based on Java API (Not Web Service)
          Nith
          • 2. Re: Searching task from API by process instance id
            hkho Level 1
            Thanks for the reply, I've tried the code and it throws an exception
            "com.adobe.idp.taskmanager.dsc.client.query.TaskQueryServiceException: Process Variable is not searchable. VariableName=id"
            I tried to add a new variable processId to the workflow and set the processId=id in the flow, then i filter by the processId and it works. But its a weird to duplicate the same same information in the process. Thanks.
            • 3. Re: Searching task from API by process instance id
              $Nith$ Level 4
              Alternate option:
              Do not add condition; rather just loop through the returned result and compare task task with its process id.
              long myProcessId = 556677;
              for(int i=0;i<result.size();i++)
              TaskRow myTask = (TaskRow)result.get(i);
              if(myTask.getProcessInstanceId()==myPorcessId)
              // I found the tasks of myProcessId
              Nith
              • 4. Re: Searching task from API by process instance id
                avi_nyc
                Hi Nitin,
                My question is what is the difference between process and process instance? Can you please explain with an example? When I say process instance that means each process instance is unique because its initiator is different? or is there any other condition to differentiate between the processes?
                Thanks!
                • 5. Re: Searching task from API by process instance id
                  $Nith$ Level 4
                  You design a workflow to automate a Leave Request for your organization. This worflow is a process.
                  This process has no effect unless someone start a Leave Request. In otherwords just invoking the process and get the results out of it.
                  Once a process is invoked, an instance (similar to how an object created for a class) will be created and executed within its own context.
                  Each time when a user or another process invokes a process, a new process instance will be created.
                  Each process instance is unique irrespective of the requester; i.e. If you request Leave for three time, it will create three unique process instances.
                  Nith
