2 Replies Latest reply on Oct 17, 2012 10:37 AM by KScale
    mxmlc/compc error
    MartinHviid Level 2
      Hi
      I'm trying to setup a Ant script to compile my code, but I keep getting an error regarding an [Embed]
      Kol: 3: Fejl: '/../assets/images/info.png' kan ikke fortolkes til kodeoverførslen
          [compc]
          [compc]           [Embed(source="/../assets/images/info.png")]
          [compc]   ^
          [compc]
          [compc] C:\Documents and Settings\Administrator\.hudson\jobs\ProcessGuide\workspace\src\dafolo\processguide\core\components\AbstractModelCommitingUIComponent.as(46):
      Kol: 3: Fejl: Koden /../assets/images/info.png kan ikke overføres.
      I can't seem to get an english version of the error, but translated directly it says:
      Col: 3: Error:'/../ assets / images / info.png 'can not be interpreted to code transfer
      Col: 3: Error: Code / .. / assets / images / info.png cannot be transferred.
      I've also tried calling it directly from command, but I get the same error.
      I've tried changing the [Embed] a bunch of times, but it just keeps on failing.
      Martin
        • 1. Re: mxmlc/compc error
          MartinHviid Level 2
          Sry, I'll just post my Ant script:
          <project name="ProcessGuide" default="compile">
          <!-- load previously defined configuration properties file -->
          <property file="build.properties" />
          <!-- points to our flexTasks.jar we copied to the libs folder to distribute with the project -->
          <taskdef resource="flexTasks.tasks" classpath="C:/Documents and Settings/Administrator/Desktop/flexTasks.jar"/>
          <!-- Build and output the Main.swf-->
          <target name="compile">
          <compc output="Main.swc">
          <include-sources dir="./src" includes="**/*.as **/*.mxml" />
          <source-path path-element="C:/Documents and Settings/Administrator/Desktop/4.5.0.17689/frameworks"/>
          <compiler.debug>false</compiler.debug>
          <compiler.library-path dir="C:/Documents and Settings/Administrator/Desktop/4.5.0.17689/frameworks" append="true">
                          <include name="libs" />
                      </compiler.library-path>
          </compc>
          </target>
          </project>
          • 2. Re: mxmlc/compc error
            KScale
            The error in English says that it can't be transcoded.
            I ran into a lot of these when I switched to command-line building. My embedded resources were coming from another project. I had to change the path in the Embed and add the resources folder as a -source-path.
