3 Replies Latest reply on Jan 11, 2011 11:09 PM by Tanu Jain
    Problem with Filter function in bubbleSeries
    Tanu Jain Level 2
      I have a bubbleSeries. Its dataprovider has item values having both blank('') and negative values. I don't want to show such values, hence I have used a filter function in which a check is made and adds those items which are valid.
      I have data for various years so I have used interpolation effect.
      While playing the animation or viewing data for different time series, a small bubble is displayed on top-left corner of the chart which is not part of the valid data.
      If I dont use a filter function, I dont get this small bubble on top-left corner. But as per my requirements, I need to have a filter function.
      Please help me in guiding through the reason of such behavior of filter function.
      Tanu
        • 1. Re: Problem with Filter function in bubbleSeries
          Gregory Lafrance Level 6
          Its often good to boil your code down to a minimal yet complete application that still exhibits the issue.
          While boiling down the code, you may discover the issue yourself, but at least you will have a minimal yet complete code sample to post here, and then a solution will come very soon in most cases.
          • 2. Re: Problem with Filter function in bubbleSeries
            Tanu Jain Level 2
            I have used following filter function:
            public function myFilterFunction(cache:Array):Array
                            var filteredCache:Array=[];
                            var n:int = cache.length;
                            for(var i:int = 0; i < n; i++)
                                var isValid:Boolean = true;
                                var bubbleSeriesItem:BubbleSeriesItem = BubbleSeriesItem(cache[i]);
                                var bubbleData:BubbleData = bubbleSeriesItem.item as BubbleData;
                                 if(bubbleData.x == ""  || bubbleData.y == "" ||bubbleData.z == ""  )
                                    isValid = false;
                                if(isValid)
                                    filteredCache.push(bubbleSeriesItem);
            I have put following series interpolate effect on the bubbleSeries.
                <mx:SeriesInterpolate id="interpolateEffect" duration="1000" easingFunction="Linear.easeOut" elementOffset="0"/>
            Tanu
            • 3. Re: Problem with Filter function in bubbleSeries
              Tanu Jain Level 2
              Hi Gregory,
              Please find below the sample code which shows a small bubble on top-left corner when animation is played. We need to click on "play" button to start the animation and "stop" button to stop the same.
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             minWidth="955" minHeight="600"
                             creationComplete="init()" >
                  <fx:Declarations>
                     <mx:SeriesInterpolate id="seriesEffect" duration="1000"  easingFunction="Linear.easeIn"/>
                  </fx:Declarations>
                  <fx:Script>
                      <![CDATA[
                          import mx.charts.series.items.BubbleSeriesItem;
                          import mx.collections.ArrayCollection;
                          import mx.effects.easing.*;
                          import mx.events.FlexEvent;
                          private var oTimer:Timer =  new Timer(1000);
                          private var currentDp:int = 1;
                          [Bindable]
                          public var expenses1:ArrayCollection = new ArrayCollection([
                              { Profit:10, Expenses:10, Amount:''},
                              { Profit:'', Expenses:50, Amount:''},
                              { Profit:'', Expenses:41.6, Amount:''},
                              { Profit:'', Expenses:43.6, Amount:''},
                              { Profit:'', Expenses:86, Amount:''},
                              { Profit:'', Expenses:11.4, Amount:''},
                              { Profit:'', Expenses:99.2, Amount:''},
                              { Profit:'', Expenses:12.8, Amount:''},
                              { Profit:'', Expenses:'', Amount:10}
                          [Bindable]
                          public var expenses2:ArrayCollection = new ArrayCollection([
                              { Profit:30, Expenses:'', Amount:10},
                              { Profit:95, Expenses:-90, Amount:50},
                              { Profit:20, Expenses:60, Amount:23},
                              { Profit:67, Expenses:'', Amount:56},
                              { Profit:-23, Expenses:56, Amount:34},
                              { Profit:70, Expenses:30, Amount:93},
                              { Profit:22, Expenses:'', Amount:10}
                          private function init():void
                              oTimer.addEventListener(TimerEvent.TIMER,onTick);
                              bubbleSeries.dataProvider = expenses1;
                         public function onTick(event:TimerEvent):void
                              if(currentDp == 1)
                                  bubbleSeries.dataProvider = expenses2;
                                  currentDp = 2;
                              else
                                  currentDp = 1;
                          private function clickHandler():void
                              oTimer.start();
                                  if( bubbleSeriesItem.item.Profit == "" || bubbleSeriesItem.item.Expenses == "" || bubbleSeriesItem.item.Amount == "")
                                      isValid= false;
                                  if(isValid)
                              return filteredCache;
                  </fx:Script>
                  <mx:Button x="10" label="Play" click="clickHandler()"/>
                  <mx:Button x="250" label="stop" click="{oTimer.stop()}"/>
                  <mx:VBox x="10" y="100" width="80%" height="70%" label="Bubble" >
                      <mx:BubbleChart id="bubbleChart" width="100%" height="100%" showDataTips="true"
                                      minRadius="5" maxRadius="15">
                          <mx:series>
                              <mx:BubbleSeries  id="bubbleSeries"
                                                showDataEffect="{seriesEffect}"
                                                xField="Profit" yField="Expenses" radiusField="Amount"
                                                filterFunction="myFilterFunction"
                          </mx:series>
                          <mx:horizontalAxis>
                              <mx:LinearAxis id="horLinAxis"  minimum="-100" maximum="100" />
                          </mx:horizontalAxis>
                          <mx:verticalAxis>
                              <mx:LinearAxis id="verLinAxis" minimum="-100" maximum="100" />
                          </mx:verticalAxis>
                      </mx:BubbleChart>
                  </mx:VBox>
              </s:Application>
              Please help.
              Tanu
