1 Reply Latest reply on Jan 5, 2011 8:38 AM by Gregory Lafrance
    Localization and FlexMojos
    Fredericci
      Hi Guys!
      I have a problem with localization and FlashBuilder... my project
      compiles and works fine....
      But, if  open in the FlashBuilder some problems appear...
      Messages in Problems view:
      Unable to resolve resource bundle "components" for locale "en_US".
      Unable to resolve resource bundle "controls" for locale "en_US".
      Unable to resolve resource bundle "core" for locale "en_US".
      Unable to resolve resource bundle "effects" for locale "en_US".
      Unable to resolve resource bundle "layout" for locale "en_US".
      Unable to resolve resource bundle "skins" for locale "en_US".
      Unable to resolve resource bundle "styles" for locale "en_US".
      Unable to resolve resource bundle "textLayout" for locale "en_US".
      I know, this locales is in
      framework(framework-4.1.0.16076-en_US.rb.swc) and
      spark(spark-4.1.0.16076-en_US.rb.swc)...
      Tried put this dependencies in my pom.xml and run the command:
      mvn clean eclipse:clean flexmojos:flashbuilder
      But not work..... Can you help-me?
      Thanks!
      My pom.xml in this time is:
      <?xml version="1.0" encoding="UTF-8"?>
      <project xmlns="http://maven.apache.org/POM/4.0.0"
      xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
             xsi:schemaLocation="http://maven.apache.org/POM/4.0.0
      http://maven.apache.org/maven-v4_0_0.xsd">
             <modelVersion>4.0.0</modelVersion>
             <parent>
                     <groupId>br.com.envisia.plataforma</groupId>
                     <artifactId>Envisia2</artifactId>
                     <version>1.0.0-SNAPSHOT</version>
             </parent>
             <artifactId>EnvisiaWeb</artifactId>
             <packaging>swf</packaging>
             <name>Envisia Web Application</name>
             <build>
                     <sourceDirectory>src/main/flex</sourceDirectory>
                     <testSourceDirectory>src/test/flex</testSourceDirectory>
                     <plugins>
                             <plugin>
                                     <groupId>org.sonatype.flexmojos</groupId>
                                     <artifactId>flexmojos-maven-plugin</artifactId>
                                     <version>${flexmojos.version}</version>
                                     <extensions>true</extensions>
                                     <dependencies>
                                             <dependency>
                                                     <groupId>com.adobe.flex</groupId>
                                                     <artifactId>compiler</artifactId>
                                                     <version>${flexframework.version}</version>
                                                     <type>pom</type>
                                             </dependency>
                                     </dependencies>
                                     <configuration>
                                             <sourceFile>br/com/envisia/plataforma/view/Main.mxml</sourceFile>
                                             <debug>true</debug>
                                             <contextRoot>Envisia2</contextRoot>
                         <runtimeLocales>
                             <locale>en_US</locale>
                         </runtimeLocales>
                         <locales>
                         </locales>
                         <mergeResourceBundle>false</mergeResourceBundle>
                                     <themes>
                                        <theme>${project.build.directory}/themes/spark-theme.css</theme>
                                        <theme>${project.build.directory}/themes/halo-theme.swc</theme>
                                     </themes>
                                     </configuration>
                             </plugin>
                             <plugin>
                                     <executions>
                                             <execution>
                                                     <goals>
                                                             <goal>wrapper</goal>
                                                     </goals>
                                             </execution>
                                     </executions>
                                       <configuration>
                                             <outputDirectory>${project.build.directory}/EnvisiaWeb</outputDirectory>
                                         <parameters>
                                           <title>Envisia</title>
                                           <width>100%</width>
                                           <height>100%</height>
                                         </parameters>
                                         <htmlName>index</htmlName>
                                       </configuration>
                             </plugin>
                             <plugin>
                                <artifactId>maven-dependency-plugin</artifactId>
                                   <executions>
                                      <execution>
                                         <id>copy-themes-for-flex4</id>
                                         <phase>generate-resources</phase>
                                         <goals>
                                            <goal>copy-dependencies</goal>
                                         </goals>
                                         <configuration>
                                            <includeTypes>swc,css</includeTypes>
                                            <outputDirectory>target/themes</outputDirectory>
                                            <overWriteIfNewer>true</overWriteIfNewer>
                                            <includeGroupIds>com.adobe.flex.framework</includeGroupIds>
                                            <includeArtifactIds>halo,spark</includeArtifactIds>
                                            <includeClassifiers>theme</includeClassifiers>
                                            <stripVersion>true</stripVersion>
                                         </configuration>
                                    </execution>
                                 </executions>
                             </plugin>
                     </plugins>
             </build>
             <dependencies>
                     <dependency>
                             <groupId>com.adobe.flex.framework</groupId>
                             <artifactId>flex-framework</artifactId>
                             <type>pom</type>
                     </dependency>
                     <dependency>
                             <groupId>org.swizframework</groupId>
                             <artifactId>swiz</artifactId>
                             <version>1.0.0</version>
                             <type>swc</type>
                     </dependency>
                     <!-- Themes -->
                     <dependency>
                        <artifactId>halo</artifactId>
                        <classifier>theme</classifier>
                        <type>swc</type>
                        <scope>theme</scope>
                     </dependency>
                     <dependency>
                        <artifactId>spark</artifactId>
                        <type>css</type>
                     </dependency>
                     <!--  Tests -->
                     <dependency>
                             <groupId>com.adobe.flexunit</groupId>
                             <artifactId>flexunit</artifactId>
                             <version>0.85</version>
                             <type>swc</type>
                             <scope>test</scope>
                     </dependency>
             </dependencies>
      </project>
