4 Replies Latest reply on Jan 14, 2011 1:09 PM by deansy55
    insert and upload images
    Level 1
      hi,
      this is probably really simple.  i have used insert record wizard a whole load of times and the upload file button to upload docs in the past no problem.
      however i need to be able to allow the user to upload properties with images into the database and wondered if anyone had a tutorial or how i would go about this with upload and insert record?
      many thanks
        • 1. Re: insert and upload images
          Günter Schenk Level 4
          Are you talking about storing images in BLOB fields ? This isn´t supported.
          Cheers,
          Günter
          • 2. Re: insert and upload images
            Level 1
            thanks gunter, i actually found it in the help file.  i am storing the images in a folder on the server.  only issue is i cannot seem to get it to display the image.  i can see the upload is working and the images are on the folder but unable to get it to display the image so far.
            is there a way within addt to have it like a slideshow to display the images?
            cheers
            • 3. Re: insert and upload images
              If all uploaded images have been stored in one shared folder, the src attribute of your image tag needs to contain both a static element (path/to/folder) plus the recordset value which represents the current filename, example:
              img src="path/to/folder/<?php echo $row_queryname['filename']; ?>"
              Cheers,
              Günter
              • 4. Re: insert and upload images
                Level 1
                Thanks gunter
