1 Reply Latest reply on Jan 18, 2011 3:06 AM by komalbhagia
    Issue with tabbed browsers
    komalbhagia
      Ours is a SSO enabled application. The technology used is Flex 3, Java 5 and Oracle. And BlazeDS is used for communication between Java and Flex.
      We are getting the following error:
      Error----------[FaultEvent fault=[RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: 'http://invportal.geam.corporate.ge.com/GEAMInvestmentPortal/messagebroker/amf'"] messageId="3D06F2A6-84A8-DFCF-BA64-EF4A7C0C34CF" type="fault" bubbles=false cancelable=true eventPhase=2]
      This occurs when another SSO enabled application is opened in separate tab. I follow the following steps to replicate the issue:
      - Open IE and open my application. The page load with data  (which signifies that the AMFchannel is working fine)
      - Open a new tab or new IE Window.
      - Open another SSO application in that tab
      - Then Switch context back to the my application. Change data to get data from database. The above written error comes.
      - This issue comes across all modules. Ie from whatever module you leave and come back after a new tab or IE window, this issue is prevelant
      Request your help with the same. When I googled I came across below links with similar issue
      http://forums.adobe.com/thread/426932
      http://bugs.adobe.com/jira/browse/BLZ-428
