2 Replies Latest reply on Jan 6, 2011 2:04 PM by learner_doug
    Modify Elastic parameters
    learner_doug Level 1
      I'm useing "Elastic" as a easer for a Move animation.  The elastic bounces a bit too much for my taste.  Is there a failry easy way to modify the amount of "bouncing" it does?  (I'm going to post this as another question as well, regarding the public variables)
      mxml CODE to define animation/effect:
      <fx:Declarations>
      <s:Move id="moveRight"
      target="
      {blackBox}"
      duration="
      1200"
      xTo="
      {changeX}"
      yTo="
      {changeY}"
      easer="
      {stretchIt}" />
      <s:Elastic id="stretchIt" />
      </fx:Declarations>
      AS CODE:
      // incrementor variable to keep track of where the infoBox is currently
      Bindable] public var currMS:uint = 1;
      Bindable] public var changeX:Number = 0;
      Bindable] public var changeY:Number = 0;
      // Keeps track of the current MileStone
      // main function including case statements
      public
      function chooseMS(event:MouseEvent):
      void
      switch(currMS)
      case 1: // to Milestone 2
      //blackBox.move(50,130);
      currMS++;
      changeX = 50;
      changeY = 130;
      wgText.text = ebs_newMS2;
      ow2.visible =
      true;
      wh2.visible =
      true;
      moveRight.end();
      moveRight.play();
      break;
      ...  the rest of the switched cases are here...
        • 1. Re: Modify Elastic parameters
          Gregory Lafrance Level 6
          I extended Elastic and override the ease() function.
          To achieve the effect you see in the sample code, I changed the amplitude to 1 and the period to .6.
          If this post answers your question or helps, please mark it as such. Thanks!
          http://www.stardustsystems.com
          Adobe Flex Development and Support Services
          ------------- myComponents/MyElastic.mxml -------------
          <s:Elastic xmlns:fx="http://ns.adobe.com/mxml/2009"
            xmlns:mx="library://ns.adobe.com/flex/mx">
            <fx:Script>
              <![CDATA[
                import mx.effects.easing.Elastic;
                private var totalChange:Number = 1;
                private var duration:Number = 1;
                private var amplitude:Number = 1;
                private var period:Number = .6;
                override public function ease(fraction:Number):Number
                  return mx.effects.easing.Elastic.easeOut(fraction, 0,
                    totalChange, duration, amplitude, period);
            </fx:Script>
          </s:Elastic>
          ------------- test.mxml (main app) -----------------
          <?xml version="1.0"?>
          <s:Application
            xmlns:comp="myComponents.*">
            <fx:Declarations>
              <s:Bounce id="bounceEasing"/>
              <comp:MyElastic id="elasticEasing"/>
              <s:Move id="moveRight" target="{myImage}"
                xBy="500" duration="2000" easer="{elasticEasing}"/>
              <s:Move id="moveLeft" target="{myImage}" xBy="-500"
                duration="2000" easer="{bounceEasing}"/>
            </fx:Declarations>
            <s:Panel id="examplePanel"
              title="Bounce and Elastic Effect Example"
              width="800" height="75%">
              <s:HGroup id="detailsBox" width="50%" top="5" left="5">
                <s:Label width="99%" color="blue"
                         text="Click the buttons to watch the effect."/>
                <s:Button label="Move Right" bottom="10" left="5"
                          click="moveRight.end();moveRight.play();"/>
                <s:Button label="Move Left" bottom="10" left="100"
                          click="moveLeft.end();moveLeft.play();"/>
              </s:HGroup>
              <mx:Image id="myImage" top="40" width="200"
                        source="@Embed(source='assets/logo.jpg')"/>
            </s:Panel>
          </s:Application>
          • 2. Re: Modify Elastic parameters
            Took me a while to digest this.  Thanks very much - very nice material.
