4 Replies Latest reply on Jan 6, 2011 2:49 PM by BK_POHS
    Math ALT Codes in RichTextEditor
    BK_POHS
      I have been using the RichTextEditor and Spanish symbols all seem to work just fine out of the box, like ALT+168 for the upside down ? etc. However, I'm having issues with several math symbols.  Is there a way to enable these alt codes in the RTE somehow?
      A few of the symbols I need are:
      ALT+232 for the Greek Symbol Phi
      ALT+233 for the Greek Symbol Theta
      ALT+236 for the Infinity Symbol
      ALT+242 for Greater than or Equal to Symbol
      ALT+243 for Less than or Equal to Symbol.
      Anyone out there had any experience with this or have any ideas on how to implement these shortcuts within the RTE?
      Brian
        • 1. Re: Math ALT Codes in RichTextEditor
          drkstr_1 Level 4
          You can use the HTML character code.
          http://www.htmlcodetutorial.com/characterentities_famsupp_69.html
          for example:
          <s:Label text="Copyright &#169" />
          • 2. Re: Math ALT Codes in RichTextEditor
            BK_POHS Level 1
            Not really the solution I need.  What I'm looking for is basically the same usability you would get from any
            text editor, where a user can be typing/writing out something then whenever they need a special character, just hit ALT+#### and it
            will insert the correct symbol.  Asking users to somehow throw in HTML text won't work b/c most of our user base doesn't know HTML.
            Thanks though
            • 3. Re: Math ALT Codes in RichTextEditor
              drkstr_1 Level 4
              Have you confirmed if the issue is a character encoding issue, or an issue with the short cut keys?
              If the character can be displayed, you can always listen for the key presses and insert the character when a matching combo is entered.
              • 4. Re: Math ALT Codes in RichTextEditor
                BK_POHS Level 1
                Its not an encoding issue, because any of these symbols can be cut and pasted in from word and they all display perfectly fine.
                I figured we could do listeners in the worst case scenario but I figured I'd hit the forums first, because there are certain ranges that do work w/ the ALT codes, such as Spanish characters.  In my mind I guess I thought if some ALT codes work, maybe there's a way to make others work as well.  So I thought I'd see if someone out there knew how to work some of that magic.  I know there are a bunch of knowledgeable people on these forums, as well as Adobe Employees that frequent so I was hoping for some good luck I suppose
                Message was edited by: BK_POHS
