1 Reply Latest reply on Jan 12, 2011 3:52 AM by Linda Nicholls
    How to  fit text  around a planet
    benyboyrm
      hi all
      i just create a nice planet and now im trying to make my text fit around the planet not just like a circle but
      like a ring i try a lot of thing but dosent work nice  now can someone give me a trick or a link to a great tutorial to make my text fit nice around a sphere planet
        sorry for my bad anglish im french
        • 1. Re: How to  fit text  around a planet
          Linda Nicholls Level 4
          If this is what you are trying to do, follow the steps below.
          - Draw an elipse for your planet
          - Draw a second, flattened ellipse to create a ring that will appear to circle the planet.
          - Type the text you want to have circle the planet
          - Press Shift and select the ring ellipse and the text, and then from the main menu bar, choose Text > Attach to Path.
          - From the main menu bar choose Text > Orientation > Skew Vertical
          - Adjust the text along the ellipse with the Kerning and Offset tools in the property panel until it looks the way you want
          - Use the knife tool to slice the planet in half horizontally
          - In the Layers panel, move the bottom half of the sliced planet shape above the text object
