1 Reply Latest reply on Jan 10, 2011 9:17 AM by Chris W. Griffith
    How do I integrate flash catalyst with dreamweaver?
    tedndinya Level 1
      How do I send a project from frash catalyst to dreamweaver and how do I open it in dreamweaver so that I can publish it?
        • 1. Re: How do I integrate flash catalyst with dreamweaver?
          Chris W. Griffith Adobe Community Professional
          There is no direct integration between Flash Catalyst and Dreamweaver, so you are going to manually have to merge the contents. When you publish from FC, make sure you select the deploy to web option, then you need to copy all of the files and folders into where you have your existing Dreamweaver content.
          Then open the Main.html file, there you will see the SWFObject code that you can merge into your existing html file.
          Hope that helps point you in the right direction,
          Chris
