1. Re: Encore Crashes When Opening Older Projects
John T Smith Jan 7, 2011 8:07 AM (in response to Jennifer Elkan)Based on (mostly) reading about similar problems in the Premiere forums, I would say this is a versioning problem for both Premiere and Encore
The "gist" of what I've read is that someone may "usually" open a ONE version back project file, and SOMETIMES a two version back project file, anything over that is not going to work
2. Re: Encore Crashes When Opening Older Projects
Jennifer Elkan Jan 7, 2011 9:13 AM (in response to John T Smith)Thanks John. That's kind of what I was thinking. I would have hoped that newer versions of Encore or Premeire could have given the option to update the file when opening if for the first time in the same way that Lightroom does for older catalogs.
Alright Adobe you have your homework cut out for you.
3. Re: Encore Crashes When Opening Older Projects
John T Smith Jan 7, 2011 9:26 AM (in response to Jennifer Elkan)>Adobe you have your homework cut out for you
Since this is a user-to-user forum, with the space provided by Adobe, you will need to file a request
Feature Request https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
4. Re: Encore Crashes When Opening Older Projects
Jennifer Elkan Jan 7, 2011 9:51 AM (in response to John T Smith)Done.
Thanks again John.
