4 Replies Latest reply on Jul 6, 2007 4:49 AM by cicnats
    listener onEnterFrame ?
    chrisatflash Level 1
      Hello,
      I am trying to make a listener to an OnEnterFrame event.
      But it does not work.
      Does anyone know what i am doing wrong?
      Regards,
        • 1. Re: listener onEnterFrame ?
          Level 7
          Hi Micheal,
          the enterFrame event is an event belonging to a timeline/movieclip. The
          onEnterFrame eventhandler therefore should be attached to a timeLine object.
          In AS2 that would be a movieClip object. Those do not support the
          addListener method (see helpfiles) so it would be:
          movieClipInstance_mc.onEnterFrame = function () {
          trace ("some text ");
          In AS3 I'm still a bit shaky, but this would work:
          function my_onEnterFrame(event:Event){
          trace("frameupdate in: " + event.target.name);
          movieClipInstance_mc.addEventListener(Event.ENTER_FRAME, my_onEnterFrame);
          First declare a function and then add an eventListener to the movieClip
          instance.
          HTH,
          Manno
          Michealnl wrote:
          > Hello,
          > Regards,
          > var listen:Object = new Object();
          > listen.onEnterFrame = function () {
          > onEnterFrame.addListener(listen);
          Manno Bult
          http://www.aloft.nl
          • 2. listener onEnterFrame ?
            cicnats Level 1
            err.. what?? you don't need a listener for an onEnterFrame event ;)
            you assign it either to the current timeline with
            onEnterFrame = function() {...
            or
            this.onEnterFrame = function() {...
            or to a specified movie clip from code outside the movieclip:
            mc_name.onEnterFrame = function() {...
            or directly to a movieclip that you select on stage and open the actions panel
            onClipEvent(enterFrame) {...
            but you don't need a listener for that.. what are you trying to make?
            but if you did want to set a listener for something else, it wouldn't work like in your code:
            onSomeEvent.addListener(listener_object);
            but
            object_that_requires_some_listener.addListener(listener_object);
            in other words, you attach a listener object to an object that requires listeners for certain events, not to the events themselves.
            try looking at the reference for MovieClipLoader, for example, to get a clearer idea:
            http://livedocs.adobe.com/flash/8/main/wwhelp/wwhimpl/common/html/wwhelp.htm?context=LiveD ocs_Parts&file=00002539.html
            • 3. Re: listener onEnterFrame ?
              Thanks!
              I did not know that object on the timeline are connected to the onEnterFrame event.
              To cicnats : The reson why i do this, because i want to delete an onEnterFrame function.
              But when i do delete this onEnterFrame is delete all the onEnteFrame functions.
              • 4. Re: listener onEnterFrame ?
                cicnats Level 1
                ok, I don't know as3, so I can't help there..
                uh.. that shouldn't happen.. every movieclip and the timeline have their own onEnterFrame event handling function.. deleting one function shouldn't delete the others..
